01-05-2021, 03:57 PM | #1 |
Rear axle ID help
I just acquired a rear end and flat bed for a "spare parts" crewcab I am piecing together, and I could use some help in identifying it. I think its a Dana 70, but I'm not completely sure.
Bonus points if anyone can tell me what truck it came out of. I was wishfully thinking it would be nice to be able to just swap the whole suspension over as the frame is currently bare on the rear suspension. As always, thanks everyone for all the help. Your collective knowledge is priceless.
Carson 1995 Sonoma--LT1/T56, full suspension mods, curvy road style <---Hasn't moved in years 1967 Camaro--undergoing restification <-- 1975 Blazer--thats what I'm here for 1978/84 C30 Crew Cab--Going to try for a spare parts build using mostly Suburban parts... |
01-05-2021, 05:14 PM | #2 |
Moderator
Re: Rear axle ID help
GM liked to use Dana 70 axles for dually trucks of this vintage.
It has a Dana-ish look to it. Specifically the case spreader tool recesses and fill plug in the axle cover.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
01-05-2021, 11:12 PM | #3 |
How many bolts are holding the diff cover on?
If it is a Dana, look on the casting..what it is will be cast into....like this..
01-06-2021, 10:05 AM | #4 |
Dana rear for sure .
Show us a pic of the axle flange were it bolt to the wheel hub . What dia are the tubes ? Can you wire wheel it and see if the stamped in B.O.M. # is still able to be read ? If so that can be searched for ALL its built for info . And gm used them yes for WIDE drw trucks with a box and fiberglass flares . Cab & chassis got 14ff narrow drw axle .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
01-06-2021, 11:46 AM | #5 |
I can't quite get to the whole thing as it sits, there is a fuel tank directly behind the housing. But I was able to get a few more pictures of the markings I can see as it sits. Also, the axle tubes are 3 1/2".
Anybody have any guesses yet on the make of the chassis? I suspect its a Ford, but I'm not positive. Its torch cut just ahead of the flat bed. I suppose judging from where I got it, it could even be bigger than a 1 ton. They had a pretty nice C50 at one point that I narrowly missed out on.
01-06-2021, 11:55 AM | #6 |
Judging by the brake drum flange--not GM pic of the lug nut area or not so close up of the frame area. BUT with the info provided a DANA 70B
01-06-2021, 12:50 PM | #7 |
possible ford frame .
as i asked and now another pics of lugnut / hub / axle area in the center of the rim . and since its 3.5" dia tube its NOT a dana 70 HD from a gm DRW pickup / box fender flare truck .
01-07-2021, 02:27 PM | #8 |
Moderator
The main consideration is the distance between spring perches and whether the brake backers will clear the frame etc and the tires will clear with the current wheel backspacing.
If the spring perches will mate with the leaves in your truck you can likely play around with wheels to make it fit. As you say the shock mounts are weld on pieces so no beg deal. For that matter you can grind off and weld on spring perches too. That's how they swap Ford 9" axles into anything they want to. You will have Ford wheels and axle on the back of your GM so the next guy is going to scratch his head.
01-08-2021, 05:10 PM | #9 |
The frame I have does not have any rear-rear leaf spring hangers (or overload pads), what width perches should I be aiming for? The 2wd and 4wd are different? And the cab and chassis are different from either of those?
The ford wheels have a larger hub diameter, correct? If thats the case, can I use a ford wheel on the front, at least for the sake of one spare? Sorry for all of the questions, I am trying to do this on a really tight budget and when I get started I will need to at least have a roller fairly quickly due to space concerns. Thanks for all of the help so far.
01-08-2021, 05:43 PM | #10 |
Moderator
Since you need the springs and hangars and you're on a shoestring budget.... One fairly easy option is to mount the Ford spring hangars on the GM frame.
If you go that route the distance between the inboard edges of the spring hangars is the only measurement that you'll need to worry about. It will need to match the distance across the outside of the frame rails. You can move the perches inboard or maybe even a little outboard on the axle if needed... while being careful of your tire clearance to the spring pak and any other protruding hardware. Is that off a school bus or F600 ish chassis?
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-08-2021 at 05:53 PM. |
01-08-2021, 06:24 PM | #11 |
I had considered that, my big concern would be exactly how to locate the rearmost hangers. Would they be placed with or without weight on the springs.
Also, this chassis may be a keeper for a larger project in the future and I don't want to go too crazy or irreversible. The rear could definitely be from a F600-ish truck, it came from the remnants of a pretty big construction company.
01-08-2021, 09:23 PM | #12 |
The rear most hangers would need to be mounted with the same measurement from the front hangers that is on the donor frame
01-08-2021, 11:19 PM | #13 | |
And being a dana 70 its NOT a f600 rear cut off .
01-09-2021, 12:15 AM | #14 |
1978 F-350 1 Ton Pick-up, Dual Wheel
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
01-09-2021, 04:26 PM | #15 | |
Moderator
I asked the question because the frame just looks bigger than a full ton frame. Some 70's school buses have a double C-rail frame or what looked like it IIRC. I figured someone might know.
