Old 01-12-2021, 05:42 PM   #1
steeeeeve
vibration maintaining cruising speed
hi fellas
68 c10
350
700r4
the truck is running great but if i'm cruising +-60mph with about 1/8 throttle to maintain speed i get a vibration that feels like i'm running over small shoulder bumps. if i let off the gas it goes away, if i give it a touch of gas it goes away.
i can't tell if its the engine or transmission.
any ideas what to look for? or just avoid 1.8 throttle position?
thanks steve
**** i'm thinking it's getting lean between idle circuit to cruise
steeeeeve is offline   Reply With Quote
Old 01-12-2021, 06:25 PM   #2
Southcity
Southcity's Avatar
Re: vibration maintaining cruising speed
Hard to say what it is and I'm certain others will chime in with suggestions. I usually start with the easy stuff and use the process of elimination.
1. Any balance weights missing from any of your wheels?
2. Check to see that motor/transmission mounts are ok
3. Did it just start happening recently?
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 01-12-2021, 06:42 PM   #3
geezer#99
geezer#99's Avatar
Might be a transition spot between idle and power circuits in the carb.
Try in 3rd gear at the same speed to see what it does.
If no vibration try in 3rd gear at the same rpm as it is in o/d.
Old 01-12-2021, 06:43 PM   #4
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
1st thing I would check would be U Joints and Center Support Bearing
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 01-12-2021, 06:52 PM   #5
67/Heaven
67/Heaven's Avatar
+1 I had the same issue and turned out to be U Joints
67/Heaven is offline   Reply With Quote
Old 01-12-2021, 09:21 PM   #6
BigBird05
I would also try putting in neutral, then vary the throttle.
BigBird05 is offline   Reply With Quote
Old 01-12-2021, 09:27 PM   #7
Corts60
Just here to tinker
Corts60's Avatar
x2
Old 01-12-2021, 09:44 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Check if any exhaust equipment is close to anything. At that speed and torque, an exhaust part can lightly touch something and cause a noise. Coasting and harder acceleration could change the light contact and reduce the noise.
~Steven
Simi Valley, CA
Old 01-13-2021, 08:38 AM   #9
Minkota
Is the truck lowered? It could be the driveshaft angle as well as worn driveline components.
Minkota is offline   Reply With Quote
Old 01-13-2021, 10:46 AM   #10
steeeeeve
thanks for all this info guys. i will check the suggestions and look for witness marks.
more info on the truck
new 350 from jegs installed last year
rebuilt 700r4 installed a few month ago from a reputable trans shop
new driveshaft/u-joints (converted to 1 piece during trans swap)
truck is bagged
new tucked exhaust as of about a week ago. shorty hedman headers.
i've noticed it make the rumble if my foot is just slightly on the gas pedal at cruising speed. just a touch more and it goes away.
then during slow speed acceleration i think i can feel the rumble in that sweet spot for just a short instant.
Old 01-13-2021, 01:11 PM   #11
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
I have this, I think, but in my case it is right around 40mph. It's like a harmonic distortion/low rumble and what you describe with giving it a bit more gas alleviates it - though if the speed limit is 40mph that is not much of a solution ha!
I suppose the same suggestions apply, even though I don't have a 700r4 but a TH350 (with 2 piece drive shaft) ? I wished I had a 700r4!
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 01-13-2021, 05:35 PM   #12
steeeeeve
you could always let off and go a bit under the speed limit. ha! not an option
but ya. I could hold the pedal in that position and have it make that rumble strip noise for miles and miles then just give it just a touch more gas and it goes away. so weird.
