aotte1 1966 GMC K10 Suburban Project 01-14-2021, 05:42 AM
aotte1 Re: 1966 GMC K10 Suburban... 01-14-2021, 06:06 AM
aotte1 Re: 1966 GMC K10 Suburban... 01-14-2021, 06:20 AM
aotte1 Re: 1966 GMC K10 Suburban... 01-15-2021, 12:03 AM
aotte1 Re: 1966 GMC K10 Suburban... 01-15-2021, 12:46 AM
aotte1 Re: 1966 GMC K10 Suburban... 01-15-2021, 01:07 AM
roll_the_dice Re: 1966 GMC K10 Suburban... 01-15-2021, 12:25 AM
cwcarpenter98 Re: 1966 GMC K10 Suburban... 01-15-2021, 11:07 PM
aotte1 Re: 1966 GMC K10 Suburban... 01-24-2021, 01:17 AM
aotte1 Re: 1966 GMC K10 Suburban... 01-24-2021, 01:34 AM
aotte1 Re: 1966 GMC K10 Suburban... 01-24-2021, 02:43 AM
aotte1 Re: 1966 GMC K10 Suburban... 01-24-2021, 03:12 PM
aotte1 Re: 1966 GMC K10 Suburban... 01-24-2021, 03:15 PM
aotte1 Re: 1966 GMC K10 Suburban... 01-24-2021, 03:19 PM
aotte1 Re: 1966 GMC K10 Suburban... 01-24-2021, 03:25 PM
The Rocknrod Re: 1966 GMC K10 Suburban... 01-25-2021, 05:26 AM
aotte1 Re: 1966 GMC K10 Suburban... 01-26-2021, 07:43 PM
notsolo Re: 1966 GMC K10 Suburban... 01-29-2021, 04:29 PM
aotte1 Re: 1966 GMC K10 Suburban... 02-01-2021, 06:07 PM
aotte1 Re: 1966 GMC K10 Suburban... 02-01-2021, 06:12 PM
cwcarpenter98 Re: 1966 GMC K10 Suburban... 02-01-2021, 10:36 PM
350TacoZilla Re: 1966 GMC K10 Suburban... 02-01-2021, 10:58 PM
aotte1 Re: 1966 GMC K10 Suburban... 02-04-2021, 12:03 AM
aotte1 Re: 1966 GMC K10 Suburban... 02-16-2021, 01:47 PM
aotte1 Re: 1966 GMC K10 Suburban... 02-16-2021, 09:37 PM
aotte1 Re: 1966 GMC K10 Suburban... 02-16-2021, 09:49 PM
cwcarpenter98 Re: 1966 GMC K10 Suburban... 02-16-2021, 10:36 PM
aotte1 Re: 1966 GMC K10 Suburban... 02-16-2021, 10:47 PM
aotte1 Re: 1966 GMC K10 Suburban... 03-02-2021, 02:08 AM
aotte1 Re: 1966 GMC K10 Suburban... 03-12-2021, 11:30 PM
roll_the_dice Re: 1966 GMC K10 Suburban... 03-13-2021, 10:06 AM
aotte1 Re: 1966 GMC K10 Suburban... 03-13-2021, 12:14 PM
roll_the_dice Re: 1966 GMC K10 Suburban... 03-13-2021, 12:34 PM
aotte1 Re: 1966 GMC K10 Suburban... 03-17-2021, 10:50 PM
aotte1 Re: 1966 GMC K10 Suburban... 03-17-2021, 11:02 PM
aotte1 Re: 1966 GMC K10 Suburban... 03-17-2021, 11:11 PM
Ol Blue K20 Re: 1966 GMC K10 Suburban... 03-19-2021, 11:19 AM
aotte1 Re: 1966 GMC K10 Suburban... 03-22-2021, 12:12 AM
aotte1 Re: 1966 GMC K10 Suburban... 03-26-2021, 12:11 AM
aotte1 Re: 1966 GMC K10 Suburban... 03-26-2021, 12:20 AM
Ol Blue K20 Re: 1966 GMC K10 Suburban... 04-04-2021, 07:19 AM
The Rocknrod Re: 1966 GMC K10 Suburban... 04-04-2021, 08:09 AM
aotte1 Re: 1966 GMC K10 Suburban... 04-05-2021, 11:40 PM
aotte1 Re: 1966 GMC K10 Suburban... 04-10-2021, 01:02 PM
aotte1 Re: 1966 GMC K10 Suburban... 04-10-2021, 01:19 PM
DPowers Re: 1966 GMC K10 Suburban... 04-10-2021, 01:36 PM
Ol Blue K20 Re: 1966 GMC K10 Suburban... 04-10-2021, 07:29 PM
cwcarpenter98 Re: 1966 GMC K10 Suburban... 04-11-2021, 06:20 PM
aotte1 Re: 1966 GMC K10 Suburban... 04-14-2021, 08:12 PM
aotte1 Re: 1966 GMC K10 Suburban... 04-14-2021, 09:05 PM
aotte1 Re: 1966 GMC K10 Suburban... 04-14-2021, 10:00 PM
60-66 Re: 1966 GMC K10 Suburban... 06-09-2021, 09:09 AM
LT7A Re: 1966 GMC K10 Suburban... 06-11-2021, 08:50 AM
aotte1 Re: 1966 GMC K10 Suburban... 06-20-2021, 01:40 AM
aotte1 Re: 1966 GMC K10 Suburban... 11-07-2022, 11:39 PM
DPowers Re: 1966 GMC K10 Suburban... 11-08-2022, 01:35 AM
01-14-2021, 05:42 AM | #1 |
Starting 1966 GMC K10 Suburban project. Last driven around 1992, sitting since then. A friend got it for me. It is going to be a slow project that needs some work (not defined yet). My grandson and I are working together on it. Body has the usual Suburban dents along with a few more, roof is good. Inside usual rust, lower “A” pillar right side, lower kick panels, floor, inner and outer rocker right side. The body frame and supports are all solid. The front and rear frame horns were modified for aftermarket bumpers.
Photos start with disassembly. New tools for this project include, gantry crane, and distribution lift bar for G crane, higher lift floor jack, tall jack stands. The 5’ I-beam lift bar is really handy for suburban body. Photo of it later. Usual I-Pad photo sideways issue. Body being removed from frame in this picture. Overall the chassis is pretty original, shocks, brake and fuel lines, frame brackets, body mount pads, axles,transfer case , drive shafts. Last edited by aotte1; 01-14-2021 at 06:05 AM. |
01-14-2021, 06:06 AM | #2 |
Re: 1966 GMC K10 Suburban Project
Frame going to be steam cleaned. In the first photo, 2nd body mount on GMC Suburban’s is different then on chevy. It is a rubber 3/4 ton style vs solid on chevy. Will show more detailed photo of it later. Second photo shows Dana 44 axle and spiral shock. Shocks have 12/65 build date code, more detail on them later too. Third, steam cleaning removing lots of dirt. Last photo, transfer case area.
01-14-2021, 06:20 AM | #3 |
Body initial cleaning, removing lots of dirt from under side.
Again I-Pad photo issue. |
01-15-2021, 12:03 AM | #4 |
A few more photos of the body. Plan is to leave the body as is for now. First work will be to repair the frame horns. These photos of the 66’ GMC suburban body were taken while the body is resting on a suburban 2WD frame. The 4WD frame is separately being worked on. The 2WD frame is illustrated by the 5 lug front wheels, front crossmember is from a 89’ suburban. The last photo illustrates the unique suburban rear frame horn. Later frame posts will show the unique differences between suburban 4WD and 2WD rear frame sections. Also, the suburban bumpers have, unique
characteristics. Last edited by aotte1; 01-15-2021 at 12:37 AM. |
01-15-2021, 12:46 AM | #5 |
Location of 4WD decal, on 66’ GMC.
01-15-2021, 01:07 AM | #6 |
roll-the-dice, thanks for the complement. Agree the Suburban’s are unique. Also, thought this 66’ GMC 4WD is going to be a fun project.
01-15-2021, 12:25 AM | #7 |
Suburbans are so nice looking! Looks like a fun project!
01-15-2021, 11:07 PM | #8 |
Came for the 4x4 suburban, stayed because it's my favorite color
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-24-2021, 01:17 AM | #9 |
Christian,
Glad to have you onboard. Les |
01-24-2021, 01:34 AM | #10 |
Doing a little frame horn repair, both front and rear. The first photo shows the front frame horn replaced, along with an additional 3/16 steel plate reinforcement piece added to frame. This piece is mainly in front of radiator crossmember. Did same piece on both sides. Second photo shows additional reinforcement plate added to frame behind radiator crossmember. Cut the reinforcement plates out on plasma table, and included factory frame holes, so as to not be noticeable from outside frame. The plates are test fit and not welded yet. These early K10 frames are not real strong, and crack when bigger engines and wheels/tires are added. Especially in the steering gear box area. This frame had some cracks, Ved out and TIG welded.
Second photo shows the frame upside down, you can see radiator saddles pointing down. Third photo, front frame horns replaced, and frame on trailer going to be powder coated. Last photo shows front frame horns replaced. Last edited by aotte1; 01-24-2021 at 02:37 AM. |
01-24-2021, 02:43 AM | #11 |
Rear frame horn replacement.
1st). Rear frame horn section replacement with trailer hitch, cut and trimmed to fit; 2nd). Replacement section welding in; 3rd). Replacement section completed, including 1/4” reinforcement plate inside frame supporting frame sectioning and trailer hitch attachment. 4th). Shows how K10 suburban rear frame area is made from two pieces. 5th). Frame fixes mostly complete and on trailer to be powder coated. Note: The surburban/panel rear frame frame horns are unique to them. The K10 models use a one ton frame and therefor, need a two piece rear frame, riveted as shown above. The 131” one ton frame also uses riveted rear frame sections. Last edited by aotte1; 01-24-2021 at 03:03 AM. |
01-24-2021, 03:13 AM | #12 |
Photos of 1/4 reinforcement plate added to rear frame. Again cut on plasma table, with hole matching original frame holes, So no see from outside.
01-24-2021, 03:12 PM | #13 |
More, no order, some may be repeats.
01-24-2021, 03:15 PM | #14 |
More original photos II
01-24-2021, 03:19 PM | #15 |
More original III
01-24-2021, 03:25 PM | #16 |
More original IV
2nd- front rear spring hangers, cleaning. |
01-24-2021, 04:53 PM | #17 |
Great work so far! l'm a big fan of these GMC K10's, I may have missed it but is it wearing an original color?
66 GMC Suburban Custom 66 Chevy K10 Suburban |
01-25-2021, 05:26 AM | #18 |
Moderator
Thanks for the updates. Great work your doing.
01-26-2021, 07:43 PM | #19 |
Rocknrod,
Thanks for your complement, and support for this project. Plan to post some original paint images from protected areas on the suburban soon. Again think it is a 503 light green color. Not seen this color before, so need to confirm color. Will clean some protected areas and post photos of them. |
01-29-2021, 04:29 PM | #20 |
Went to a good home, nice to see its progress. Great photo's . Thanks for sharing.
02-01-2021, 06:07 PM | #21 |
Notsolo, thanks for encourage, plans include finishing frame/suspension soon, and repair rust in front floors/ right rocker. This work underway.
02-01-2021, 06:12 PM | #22 |
Color photos of area not exposed to daylight, along with one exposed to sunlight. (66’ GMC suburban) The first two photos are of areas not exposed to sunlight. Last photo of pillar exposed to sunlight. The exposed area, may look a little lighter? These areas were cleaned with 3M Finesse-it II finishing material. The light condition is shop lights. In natural light the paint may look a little lighter. Will try to get photos in natural light too.
Not familiar with GMC colors, is this code 503? Searching forum found couple other trucks, that look original paint, close to this color. Last edited by aotte1; 02-02-2021 at 11:01 AM. |
02-01-2021, 10:36 PM | #23 |
That kinda looks like 505 green to me, but I'm not sure
02-01-2021, 10:58 PM | #24 |
^ agree it looks more like the 505 Dark Green. I think that's the factory color on my 63 gmc 1500 also but called 505 Woodland Green for 63. I'm not good with all the different shades of colors but it looks like the 503 is lighter than what you have and 505 is closer match. I thought 503 was light kinda teal green or aqua green?
One place listed a code 511 Dark Aqua Metallic offered in 66 but not sure what that one looks like. Last edited by 350TacoZilla; 02-01-2021 at 11:04 PM. |
02-04-2021, 12:03 AM | #25 |
350TacoZilla, thanks for your comments on original color.
Today had a conversation with forum member very knowledgeable on GMC trucks, and has many 60 to 66’s. He reminded me that GMC paint color codes are four digits, and GMC had many more colors then chevrolet. Will look on firewall and hood for paint codes, per his suggestion. Report back on paint code findings soon. Thanks member 60-66 on this information. |
