12-18-2003, 07:12 PM | #1 |
Nothing clever
Cutting spings?
Can I do this with a cut off wheel?
If not what is the best way(s) to cut them?
Got "the Midas Touch!" |
12-18-2003, 08:45 PM | #2 |
Back from the Dead
I would think anything that can cut through the steel should work. I used a oxy-acteleyne (sp?) setup to torch mine a 1 1/2 coils shorter.
The only Carb that matters to me is the one under my hood! Salem, Oregon |
12-18-2003, 08:47 PM | #3 |
Nothing clever
what about the heat warping the coils?
12-18-2003, 09:39 PM | #4 |
67-72 Addict!
A cutoff wheel will work good.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
12-18-2003, 10:52 PM | #5 |
Back from the Dead
Well, since the coils are made of some serious steel I dont think you should have a problem with warping. We threw some intense heat on my stockers and they were fine. I just wouldn't sugest cutting more than 1.5 coils.
12-19-2003, 11:24 AM | #6 |
Years ago before drop coils could be bought we put the coil in a 5 gallon bucket of water and had the part of it we wanted to remove sticking out of the water and torched it off, the coil would sink to the bottom and quenched itself.
Rest in Peace Ed. Thanks for all the good times. |
12-20-2003, 01:31 PM | #7 |
COMING SOON...
I second the cutoff wheel...takes awhile, though.
12-20-2003, 11:24 PM | #8 |
Project56 on hold
put spring in good vise. use circular saw with "chop-saw" blade.....like butter
Shamrock Customs Forever-in-the-Future Custom Shop 2009 Mitsubishi Lancer GTS daily driver 1956 Chevy Stepside rodstoration on winter hold |
12-21-2003, 12:19 PM | #9 | |
Happy to be here
I have used just about every method you can think of and this one produces the least amount of heat on the spring. Like MOTHERTRUCKERS said, if you use a torch, put the srping in a bucket of water. This keeps the rest of the spring cool. Believe it or not, you can cut it with a hacksaw and a good blade. It takes a while, but it's not as bad as you might think. Don't ask me why I know this....
12-21-2003, 06:50 PM | #10 |
Project56 on hold
thanks, could not remember the type of blade for nothing! im just gettin old. time for ginko biloba!
