Steering shaft spline
I have a 1970-72 Monte Carlo tilt column.
I can't take the column out of my truck till I get it in the garage. Did g.m. use the same spline type/count/size shaft. across the board? I know the M/C one will have the key on the unit. and wiring will be different because of that. Any reason this can't work in the truck. The going price of rebuilt g.m. truck tilt columns is a hard to swallow pill. |
Old member
What is the spline count on the M/C shaft?
If I remember right the truck is 36 splines. Here is the one I ordered for the ramp truck tilt steering. Ensun 3/4"-36 Spline x 3/4" DD Nickel Plating Single Steering Universal U-Joint, Maximum Working Angle: 35° Degree, Total Length: 83mm (3-1/4") ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
