02-09-2021, 10:11 AM | #1 |
Mr. Cheyenne
Timing & Gas Milage
So I popped into the "What kind of gas mileage do you get with your 67-72?" and after I posted what I was getting it went south from there. I feel a bit bad since it became about me and my timing. So I am starting a new thread, mostly to see what the out come is. Or I hope there is one ;-)
Summary: Engine rebuilt to stock with a mild RV Cam, still a bit under 1k miles on the engine (say reaching 700 miles). I got 10 mpg this past Sunday for the 1st time with reasonable mixed driving. My timing is set to 12° but I found that my Vacuum Canister on my distributor leaks, takes it under 25 seconds to drop to 0 after pumping it to 15~20hg. I am trying to learn how to properly find both mechanical and vacuum timing - I am thinking I didn't do that right last night. Currently I have what the previous own put in (he bought it from Ebay), a Top Street Performance JM6701. Not much you can do with it, other than set timing. The Vacuum Canister is a odd thing that will not take a replacement off the shelf, though they are sending me one for free. During the rebuild my bother and I did talk about replacing it - just to have a known brand. I finally decided to buy from Summit this morning a PerTronix Ignitor III D7100700 with their matching coil. This unit looks very similar to the Top Street Performance distributor, its black, small-ish, and has female connections on the cap - which from a visual stand point what I am wanting. I know a lot of guys say go with a GM HEI, even go get one from a junk yard. But those things are monsters and I don't like the look of them. The deed is done and at least I should be able to support this one better than the TSP distributor. I also have a 72 Quadrajet 4BBL at Quadajet Power but I don't expect it back until March. My installed Quadrajet is from a 78 Truck that the previous owner put on and while it was rebuilt, I am not sure how well it was jetted during the rebuild (there was a lot of questions around its rebuild when my brother & buddies had it apart a few times). As I get stats from timing and MPG changes I'll try and keep this tread updated. PS: As for how the truck is running, outside of MPG, I have no complains. She takes off like a bandit, even spinning the tires if I dog it. At any speed I can give it WOT and she immediately goes. No hesitation or mis-firing that I can notice. I have had it in two different shops for various things (O'Ring replacements/Transmission leak fix) neither offered up "hey, you have timing problems". They actually both said in one way or there other, she is a nice truck and drives great. PSS:
Update for Real World MPG with my rebuilt 72 Carb from Cliff and Progression Ignition: March 25th 2022, 14mpg on a 275 mile trip on Texas Hwys from Kyle to Kilgore Texas. This is mix driving were a lot (most) is 65~75 state Hwys and little towns on the way.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 03-25-2022 at 09:22 AM. |
02-09-2021, 10:17 AM | #2 | ||
Mr. Cheyenne
Re: Timing & Gas Milage
Update Pertronix 02/09/21: Canceled my Pertronix Ignitor III D7100700. Seems the Ignitor III does not work well with older OEM Tachometers - something about multiple spark. Though it appears using the Ignitor II D100700 is okay with OEM in-dash Tach. I am now looking directly at Pertronix site and have submitted a tech question.
Changed Ported to Manifold Vacuum 02/09/21 Part II: I put about 60 miles on last night. 80% 55~70 MPH and the rest town driving. I got 12 MPG Installed PerTronix Ignitor II D100700 & Flame-Thrower II Coil 45011 02/13/21: Now getting a full 38° Max Mechanical Advance @30k, with a 12° Initial timing @650 RPMs. Also no apparent issues with my OEM Tach that I see so far. Vacuum canister on PerTronix actually works (even the TSP replacement canister I got in the mail will not hold vacuum). The changes are: New Pertronix Flame-Thrower II, New Flame-Thrower Coil & Wires. 12° initial timing, ~900 RPM idle (Park) and ~640 RPM idle (Drive). Quote:
With my newly rebuilt 72 Quadrajet done by Cliff High Performance and my newly installed Progression Ignition I got 18.5 MPG! Timing setup can be seen with Progression Ignition app (it is controlled by your phone).
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 10-31-2021 at 08:18 PM. |
02-09-2021, 11:39 AM | #3 |
Here's a good timing article written by old GM engineer John Hinckley. He helped develop the systems and he explains it very well.
http://www.camaros.org/pdf/timing101.pdf
72 C10 lwb fleetside -stock 350/350 combo |
09-26-2021, 08:39 PM | #4 | |
02-09-2021, 11:45 AM | #5 |
Here's another article by Hinckley that goes over the vac advance.
http://www.stl-vettes.com/65Vette/co...ng_Advance.pdf
02-09-2021, 11:54 AM | #6 |
Mr. Cheyenne
thank you, downloaded and saved into my Timing Folder locally!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
02-09-2021, 11:57 AM | #7 |
You're welcome. What type of distributor do you have? I didn't notice it in the other thread.
02-09-2021, 11:59 AM | #8 |
Mr. Cheyenne
I listed that up in my summery - Top Street Performance JM6701
I am now looking at a Pertronix Ignitor II D100700 but I want to know make 100% sure it will work with my stock/OEM Chevy Tach (seems I read the III does not).
02-09-2021, 12:07 PM | #9 |
Jeez, I missed that twice I looked it up and they give you almost no info on that distributor. You need to find out how many degrees of mechanical advance and vacuum advance it provides. Also, at what rpm does it allow max mech advance.
02-09-2021, 12:09 PM | #10 |
Mr. Cheyenne
I think I am done with the TSP JM6701. I more or less got from them on a call, you need to go to the "Pro" for whatever I was asking about. So I rather just go with someone else that others have actually bought and installed for better "user" help!
02-09-2021, 12:36 PM | #11 |
That doesn't sound like very good customer service. I would ditch them too.
Since you have a mild build, a HEI will work just fine and is an upgrade from the points distributor. I've used the Accel 59107 HEI on different vehicles with zero issues. They're a reliable OEM replacement, reasonably priced, and work great. I've never used one so I have no first hand experience (which means I may be talking out of my ass), but I've read from multiple sources, the Pertronix units have a high rate of failure. Lots of folks here on the board have used them with no problems, so I wouldn't really be too worried, but from what I've read on them, I'll never use one. Regardless, it sounds like it will be much better than that TSP. Since I only use HEIs, I have no recommendations for a points distributor. Cheers
72 C10 lwb fleetside -stock 350/350 combo Last edited by 68 P.O.S.; 02-09-2021 at 12:42 PM. |
02-09-2021, 01:43 PM | #12 |
Mr. Cheyenne
Called up PerTronix's support and I have to say, that was enjoyable. The support guy (Mitch I think it was) was very easily understood, helpful, and knowledgeable. He says between the Ignitor II & III either one could likely give me a Tachometer issues, where it would read up to 1k to high. Though he says it only needs a resister mod (10K 1/2 RESISTOR) added between the negative post of the coil to the tachometer wire (but he has seen many customers not need it either with my setup). He also says, the III is overkill for my application and the II is what he would recommend.
On another positive note, their website gave me a coupon code and I saved $28 bucks on my order for the Ignitor II and matching Coil.
02-09-2021, 02:13 PM | #13 |
Very nice, sounds much better than the support at TSP.
02-09-2021, 02:27 PM | #14 |
Mr. Cheyenne
I would not go as far as TSP support was bad, they just reported the fact my options were limited (none) with the distributor (which I did not even buy, it came with the truck). While I am sure I had a bit of luck, it was easier to get through PerTronix.
Now, if I have problems with the PerTronix distributor, at least I know its history and it is a choice I made (for good or bad).
02-09-2021, 03:19 PM | #15 |
Mr. Cheyenne
One thing I learned from the docs, I am 95% sure my vacuum can is connected to ported vacuum and not manifold vacuum. My vacuum line comes from the can, to the front of my Qjet to the port above the right adjustment screw.
I "think" this location is the original factory connection and from the reading this was for emissions. While this is the factory distributor vacuum can source, it is not a proper source?? Gee I hope I read that right! Edit: yes, it does make a difference - the clearly reacts to manifold Vacuum as apposed to the connect I have it on the Carb that is ported. When on the Carb ported Vacuum, there isn't a difference when I disconnect it. When I moved to manifold vacuum, I gained roughly 150 RPMs and when I disconnect it I bounce back to my idle set speed from the carb's ported vacuum. I also read here on this web page basically the same, distributor should use full manifold vacuum: Everything You Wanted to Know About Vacuum Advance and Ignition Timing Edit 2: Man, there is so much on Manifold vs Port Cab Vacuum ... talk about having a line in the sand with groups of people on either side!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 02-09-2021 at 04:21 PM. |
02-09-2021, 06:29 PM | #16 |
Who Changed This?
There were, I saw here, some vehicles with ported spark before it became an emissions requirement. Some people get pretty vociferous about their interpretation of the truth, is my take. I'm running manifold vacuum to my distributor. The engine has always run hot, and I made many incremental changes to get it to run "normally". I've used different temp gauges to verify the results, so it's not a gauge problem. The biggest help was using a high-flow thermostat.
BoT, your truck came with ported spark, and yes it was connected to the vacuum nipple on the driver's side front of the carburetor. My truck was originally ported spark, but like I said, I routed full manifold vacuum to it.
02-09-2021, 06:38 PM | #17 |
Mr. Cheyenne
With my very limited test drive, I see improvement. I shall keep an open mind and eye on it. It's an easy change either way. I'll do a 20~40 mile drive on the back roads to see how this holds up. Plus it will be a few days or more before I'll have anything to work on/replace the distributor!
Thank you for your input/information Steeveedee!
02-09-2021, 07:33 PM | #18 |
At the level of detail you are working, I would wait til you had 5k miles or more on the engine. I would be concerned that your motor is "tight" causing part of your gas mileage issue. The other items that will affect gas milage:
-what is the diameter of your tires? -does your starter turn slower when the engine is hot vs cold start? (ie engine is tight) -do you have excessive "slippage" of your torque converter (assuming it is a non lock up?) |
02-09-2021, 11:16 PM | #19 | |
Mr. Cheyenne
Sorry, I cannot say either way - need to find out what wideband means. Noted, though sounds complicated! I need to print that out, read over it to insure I understand what you have suggested. Personally, I have all the time in the word to try things out at least once! Though to remember @cj847 comment, perhaps I need to let it break in a bit more...
02-09-2021, 09:04 PM | #20 |
Do you have a wideband? I think leaning out the cruise AFR will get you the most bang for the buck. Leaner mixtures require more timing, so basically you wind up trying to lean out cruise and add in advance until you reach the point of diminishing returns or where you can’t realistically lean out the carb more without affecting part-throttle performance negatively.
I started to go down this road to get decent fuel economy out of my 396 K10, but eventually accepted the fact that, with two small kids, I was going to spend a lot more time in my 2500HD crew cab than in my K10. Not sure how to lean out cruise with a quadrajet but I believe it’s doable. |
02-09-2021, 09:23 PM | #21 |
You change the secondary metering rods. The taper of the rod coming out of the fixed office make it act like a different sized jet. Cruise should be on the primary side of the carb so not much is going to affect the milage other than proper mixture screw settings. The throttle blades are about the size of a dime on the front barrels so they run real lean as it is.
02-09-2021, 09:26 PM | #22 | |
02-10-2021, 10:06 AM | #23 |
Old member
One of the best distributers you can buy is a GM HEI out of a mid 80's vehicle. No vacuum advance. They are easy to set up and will provide you with great service.
I had one in my 71 C-10 the whole life of the 305 TPI motor with 300,000 miles on it and I put 1 module in it. They are the best and cheapest for a stock motor. My truck had the 305/700-R4 in it with 4:10 gears and I got 18 MPG out of it running 70-80 MPH. For a street truck that is used for just driving it and not hot rodding it you want beat the setup. All these boxes and stuff are hype to sell you the product but @ the end of the day your paying for nothing but fancy electrical gadgets to fail and leave you on the side of the road. One thing I always kept in mind for my trucks is drivability. I didn't want anything I couldn't get at a local parts house if I was on the road. That is something to keep in mind.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-10-2021, 11:01 AM | #24 | |
It will run like garbage on an engine without the ecu controll. |
02-09-2021, 11:18 PM | #25 | |
The air fuel mixture at cruise (and anytime the throttle is open above the off idle transfer slots) is controlled by the primary jets and the primary rods. The farther the primary throttle plates are open the stronger the signal developed by the venturies and the more fuel that pulled through the primary jets. The size of the jet sets the maximum amount of fuel and the rods fine tune that amount . There is also a throttle tip in circuit that uses senses manifold vacuum to richen the primary mixture when the throttle is moved open from a cruise. This circuit has a spring that overcomes the vacuum and lifts the rods to richen the mixture to prevent stumbling. This is the condensed Cliff Notes explanation. Poor fuel economy can be caused by the wrong jets or the wrong rod or a combination of the two. Too strong of a spring on the tip in circuit or low vacuum or both will hurt fuel economy. Improper vacuum advance operation will kill milage. The whole purpose of the vacuum advance canister is fuel economy. Leakng plugs on the bottom of the carburetor center section will hurt economy. As will at least a dozen other simple things. The mixture screws ONLY affect the fuel mixture at idle! The primary bores are 1 3/8" in diameter. Far larger than a dime. The secondary rods only control the fuel mixture of the air thar passes through the secondary bores of the carburetor. The secondaries are closed in a cruise situation. (Unless your cruising at 4500 plus rpm.under a heavy load) There are dozens of good books on carburetors out there and some of them are Quadrajet specific. They are much better at explaining all of this than I am able to. Get a book that explains carburetor operation in a manner that works for you. Read it and ask specific questions. Your truck should be getting 12 mpg around town and at least 14 mpg at a steady 60 mph on the highway. Here is a link to my Burban repair thread and there is tuning information of a similar combination to yours in various places. http://67-72chevytrucks.com/vboard/s...698377&page=19
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 02-09-2021 at 11:31 PM. |
