Photo help under bed?
Could someone please help me with a phoot of the tailgate end of under the bed? Or just insight. My fuel tank plan changed and my bed is already removed. Trying to see if tailgate hangs lower than the top of frame rails? I got my crossmembers made to support the new shock location in front of the axle and the new front side of the tank. Now configuring the tail end Thank you
Re: Photo help under bed?
Not sure exactly what you are asking about. Obviously the tailgate hangs off the end of the bed/frame. You have bed cross sills that set on top of the frame. You can mount anything up to the top of the bed cross sills, except where the sills are. There will be 1/8" rubber under each sill in top of the frame.
Bed wood is 3/4" thick , the top of the tailgate is even with the top of the bed wood. The read sill is built into the bed and bolts to the frame
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#3 | |
And mine didnt have any rubber when removing so thanks for the heads up. I'll look for those when putting back on. |
