Old 02-19-2021, 01:11 AM   #1
56 3100
56 3100's Avatar
residual valve 2 front lines
i have frame mount booster with brass proportion valve. valve has 2 outlets for front disc brakes will i need 2 2lb residual valves?
56 3100 is offline   Reply With Quote
Old 02-19-2021, 01:21 AM   #2
geezer#99
geezer#99's Avatar
Re: residual valve 2 front lines
Yup!
If you have two ports to separate lines.
Your pic shows only one front port.
geezer#99 is online now   Reply With Quote
Old 02-19-2021, 06:47 AM   #3
MiraclePieCo
MiraclePieCo's Avatar
You only need to use one of those front outlets. You can plug off the other and use a single line with a single residual valve followed by a T downstream to the L & R sides. Fewer junctions equal less chance of leaks.
Do you have front disc brakes? If the master cylinder is higher than the brake calipers (ie on the firewall) you don't need a front residual valve at all. Gravity does its job for you.
It has two front ports. One is hidden out of sight on the bottom.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 02-19-2021, 09:21 AM   #4
56 3100
56 3100's Avatar
hi geezer other port on bottom. miricle pie i have camaro clip with front disc brakes frame mounted booster. so master is down low.
Old 02-19-2021, 02:09 PM   #5
mr48chev
mr48chev's Avatar
If you run two lines from the combination valve you will need two residual valves.
My ongoing truck projects:
Old 02-19-2021, 02:11 PM   #6
56 3100
56 3100's Avatar
thanks mr48chev just have one 2lb valve at the moment. got a 3/16 Tee and a plug just debating run 2 lines or 1?
Old 02-20-2021, 11:15 AM   #7
Rickysnickers
No need to run two. One line will suffice and you don't double your workload.
Old 02-20-2021, 04:31 PM   #8
56 3100
56 3100's Avatar
getting T ready now . bending lines from master to proportioning valve now a few bends so its taking some time.
Old 02-20-2021, 07:09 PM   #9
geezer#99
geezer#99's Avatar
Don’t forget the need for a 10# valve for the back if you’re got drum brakes.
Old 02-20-2021, 10:07 PM   #10
56 3100
56 3100's Avatar
Thanks geezer have most of brake line stuff installed. 10lb valve installed for back
front valve Tee and lines
proportional valves and master lines
Old 02-22-2021, 06:03 PM   #11
cameo
Going through the same process now. I am using my line lock for the tee. not going to be a drag car, just there to save the brake shoes while turning the tires into dust
cameo is offline   Reply With Quote
Old 02-23-2021, 08:58 PM   #12
56 3100
56 3100's Avatar
Hey cameo linelock is a good Tee.
Old 02-25-2021, 05:01 PM   #13
cameo
i think what it saved me in fittings will be eaten up in rubber replacements
