02-22-2021, 10:35 AM | #1 |
Who builds the best 700R4 today?
Looking at buying a built 700R4 for my 69 C/10. Was talking to both monster and bow tie overdrive. But was wondering if anyone here had any thought as to why or why not use someone. Not looking at doing the 4l60E or 4l80E so don't need input on them. Thanks in advance for any info.
02-22-2021, 11:16 AM | #2 |
Re: Who builds the best 700R4 today?
I have no experience with Monster, but have read many bad things from others who have used them. I would check into that before having a go with them. You might want to check in with clinebarger. He's on the board. I don't know if he actually sells or not, but he's a mountain of information!! FWIW, I have a 700r4 and bought a convertor from FTI. They seem to have a pretty reputation.
02-22-2021, 11:35 AM | #3 |
Thanks for the info. I'm just not finding many reviews on this subject anymore so thats why I'm asking.
02-22-2021, 11:47 AM | #4 |
Bought mine originally from Bow Tie Overdrive. Had nothing but good experiences with them. But have changed hands since. Lasted 15+ yrs. Recently had it rebuilt locally. If you do it locally then you have direct knowledge of the business. A reputable shop should be able to rebuild one to suit your needs and then you have local support should there be issues.
Smitty '71 Short Fleetside Spring Valley, Ca. |
02-22-2021, 12:10 PM | #5 |
We have bought a few from Phoenix Transmission, and have been very happy with them. They excellent customer service as well.
Posted via Mobile Device |
02-22-2021, 12:30 PM | #6 |
x2.
02-22-2021, 12:38 PM | #7 | |
Everything was well organized and all the workstations were pristine. Also, what's really nice is they are only 50 miles from my house.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-22-2021, 12:36 PM | #8 |
If you're able to go local, it should be cheaper. I'd ask the local racers who they use. If the guy had a good reputation, I wouldn't be put off by someone doing the rebuilds in their garage.
You can have them install the one wire lock-up and modified TV cable that a lot of the aftermarket vendors use. you can request the usual performance and durability upgrades, too.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
02-22-2021, 12:58 PM | #9 |
I wasn't sold on ordering a transmission over the internet, so I got a later '92 700R4 w/30-spline input shaft from a salvage yard and had it rebuilt locally by a builder with a good reputation. I went with a 'Stage 1' option that is better than stock. He also added a hydraulic kit for the converter lockup, so no solenoid wiring or brake switch needed. I could have spent a lot more had I wanted it built for racing or heavy duty towing - it's all in what your budget will support. My suggestion is to ask some local clubs or forum members if there's a reputable builder or transmission shop in your area.
If I were to buy one via the internet I would consider buying through Summit, Pace Performance or a similar parts supplier as they may have better customer service should there be a problem, which is a reason why I bought CPP parts through Summit. They might also give you some honest information about some of their vendors if you were to give them a call. A quick look shows ACI, B&M, FTI, Hughes, Performance, & TCI as options. Monster transmissions are not available though Summit, Pace or Jegs.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
02-22-2021, 01:59 PM | #10 |
Who Me?
Precision Transmissions
300 Ross St, Amarillo, TX 79102 (806) 372-2210 It will be worth the drive.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
02-22-2021, 03:14 PM | #11 | |||
All 3 places had a price tag that varied from $28-3300 (installed/change-out). The higher end of the pricing was for just a basic rebuild, a stock converter, & install/swap. I checked w/Phoenix Trans (2hrs away) & they said it would range between $24-2800 solely depending on what the extent of the internal damage was. Included in that cost was an upgraded Vette servo, better/additional clutch packs, shift kit, & converter (w/stall speed options). I said I eventually wanted to install an STS rear mounted turbo set-up & wanted something overbuilt. They were familiar w/STS & already had a package for a proper set-up to survive their kit/s. My buddies @n2junk & @n2billet had used Phoenix on a few hot-rod builds w/good results. MY significant other & family didn't understand why I would use a shop 2hrs away when there were multiple options within 0-20mins from our area. I decided that even @ worst case scenario the cost would be around the same as the others but I'd be ahead since it would be upgraded. I had the car towed all the way out there & was immediately impressed by how clean everything was (parking lot, waiting area, & lift stalls). That was nothing compared to the rebuild tables/stations. It was hard to believe how clean the area was. Anyhoo.... 36hrs later the car was ready. They spec'd the converter based on my current app (CAI only A4/LS6 optioned edition) to help over the factory unit & then once the STS kit went in I was only a converter change away from their kit. Total price was $2480. So, even w/the $200 tow bill, I came out less than the cheapest quote for a basic stock rebuilt trans. The trans itself? Night & day difference in how the car performed. SIGNIFICANTLY woke it up. The original trans survived just a tick over 36k easy miles. The Phoenix unit was in place for @ least the next FUN 70k. When she & I split up, the car had just over 100k & as far as I know it's still going strong.
02-22-2021, 03:28 PM | #12 |
Lots of good info from everyone on here. Thanks as its really helped me make a more educated decision on what to do next. I have found out through a few phone calls that we do infact have a transmission guy here in town now that is doing the 700R4. Talked to him on the phone and plan on stopping by after work. Just hope it's not a waist of time and money. What worries me is after I told him what I have, he feels it's just a stock rebuild for me with a few extra parts needing to be beefed up.
02-23-2021, 04:00 PM | #13 | |
02-23-2021, 05:00 PM | #14 |
That last question is critical with the 700r4’s. Getting tv cable set isn’t hard but if not adjusted correctly it will ruin a 700r4 quickly.
__________________ Jeff |
02-22-2021, 02:47 PM | #15 |
Watch out for your cornhole !
Phoenix Transmission has done all of mine since 1991. I won't use anyone else.
02-22-2021, 04:24 PM | #16 |
Gearstar is local to me and has been used in all the Motor trend shows when they build stuff.
No personal experience with them but might be something to research. They dyno test all the transmissions prior to shipment and they have a 3yr 36 month warranty. https://gearstar.com/transmissions/gm/
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
02-22-2021, 04:45 PM | #17 |
SLOW BUT SURE,BUT CLOSER
Second on Gearstar
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... |
02-22-2021, 05:25 PM | #18 |
I don't want to pick on a "brand" but similar TV shows used to use Monster units that have many numerous complaints from 'regular joes' like us on these forums.
Celebrity status can come to those that fit within the productions budget even when better products are available. I also know of more than one 'builder' who uses their status to request free parts, get moved to the front of the line, require deep discounts etc or they'll move on to the next place that will meet their req's. Suspensions, engines, transmissions..... I'll take the gearheads like me first hand opinion over a magazine article or tv show episode product placement advertising any day. I trust those in the trenches w/me more.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-22-2021 at 05:30 PM. |
02-22-2021, 05:27 PM | #19 |
A friend of mine has a FTI in his 48 REO Speedwagon behind a 383. He drag races it and it seems bullet proof from what I see.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
02-22-2021, 08:08 PM | #20 |
Just got done talking to the local best transmission guy in town....got the typical runaround that I expected with having the wrong transmission, guess I have a first generation. Now he was willing to upgrade all the parts in it but its like I said again the people around here have no clue how to build it for a custom application. He had no idea how to make the lockup work if it wasn't being installed in the original car. So back to sending it off to get built. After spending the day reading everyone's reviews....looks as its going to PhoenixTransmission.
02-23-2021, 02:18 PM | #21 | |
02-23-2021, 03:37 PM | #22 | |
When OP gets his 700r4 the only to discuss next is the rear end.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
02-22-2021, 10:08 PM | #23 |
When you call Phoenix, talk to Scott Jackson. He's the manager and the dude I always deal with.
02-22-2021, 10:20 PM | #24 |
I wouldn't worry about the "complaints" you read online about Monster or some of these other transmission builders. They have sold thousands of these things, and those few problems find their way online. When there is something to ***** about, online is the first place people turn to over the past 10 years. These "I have a buddy" stories are amusing though. Of course nobody knows if the buddy failed to set the TV cable correctly, which is the most common reason these mail order 700R4s fail.
02-23-2021, 06:01 PM | #25 | |
