Old 02-24-2021, 08:24 AM   #1
Acregger
Exhaust/Mufflers
Hey guys getting about time for exhaust for my 71 k10 with a 5.3, just trying to see what you guys went with. I have had very good luck and like the sound of Magnaflows in the past but torn between 14 inch and 18 inch. I dont want it terribly loud but sound good. It little hard to listen to the sound on you tube as all the Silverado's on there have cats. Seeing your thoughts and maybe a sound clip.
Acregger is offline   Reply With Quote
Old 02-24-2021, 09:35 AM   #2
kipps
Re: Exhaust/Mufflers
I'm in a similar position. At this point, I'm looking at using a single Magnaflow Delta 50 or Delta 70 muffler. I don't mind a little rumble, but I don't want it to be loud at all. I will be installing cats on mine. I don't know yet whether I'll install a resonator or not.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 02-24-2021, 10:11 AM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I bought the Hooker Blackheart set up. Fit great, but it does need the holes cut in the trailering arm cross member.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-24-2021, 10:51 AM   #4
Acregger
What kind of modifications to hook to a 4x4 truck and the LS?
Old 02-24-2021, 11:04 AM   #5
1971Stepside
Almost Satisfied
What kind of modifications to hook to the truck and the LS?
None, if you have the holes already cut in that crossmember. The kit is designed to sit inside the frame rails and not hang down under the frame. You will also have to work out making the connection to your headers/manifolds to the pipe since they all differ, but that is pretty simple to do. You can look at the Blackheart thread in this LSx Swaps section or look at my build thread (1971 Stepside LS Build) to see more pics.
Old 02-24-2021, 11:18 AM   #6
Acregger
Cool, I looked at the website under my truck and LS swap but didnt show a kit
Old 02-24-2021, 12:56 PM   #7
1971Stepside
Almost Satisfied
https://67-72chevytrucks.com/vboard/...d.php?t=790866
Old 02-24-2021, 11:12 PM   #8
Captainfab
60-66 Nut
The 2wd Hooker Blackheart LS exhaust is not going to work on a 4 x 4 without modification
Old 02-25-2021, 10:15 AM   #9
1971Stepside
Almost Satisfied
Great point! I missed the "K" in 10. Thanks Captainfab
Old 02-25-2021, 12:38 PM   #10
Joemomma1
Joemomma1's Avatar
I have flowmaster 40 series on my 5.7 and its too loud. Wasn't a big deal as a kid but it is as an adult.
Joemomma1 is offline   Reply With Quote
Old 02-25-2021, 04:18 PM   #11
bigmoe
bigmoe's Avatar
I went with Magnaflow XL 3 chamber mufflers. I wanted something not too loud. At first I just had turn downs behind the mufflers and there was a lot of drone. Tailpipes to the back helped that. Not quiet by any means but tasteful and of course louder when you tromp on it. If anything it has too much "slap" when I step on it. May try some resonators. I have shorty headers.
bigmoe is offline   Reply With Quote
Old 02-25-2021, 08:05 PM   #12
kipps
Originally Posted by bigmoe View Post
I went with Magnaflow XL 3 chamber mufflers. I wanted something not too loud. At first I just had turn downs behind the mufflers and there was a lot of drone. Tailpipes to the back helped that. Not quiet by any means but tasteful and of course louder when you tromp on it. I have shorty headers.
Can you explain what you mean by drone? I've been hearing the term for some time, but haven't been sure. Is it simply exhaust note in the cab, or is it something worse?
Reason I ask, I'm building the truck in my signature, and I WANT to clearly hear the engine in the cab, but I want it as quiet as possible outside the truck. It's fun to have a deep exhaust note when rowing the gears, but I don't want the neighbors to say, "There he goes again..."
I know this truck will have less insulation on the firewall than the donor Tahoe did. I don't know how much I'll hear the engine itself through the firewall, without needing to add the exhaust note to it as well.
I've driven two trucks extensively that had a single glasspack and a turn down exhaust underneath the bed. One was a 1973 f100 with a 360fe, and the other is a 1981 f150 with a 300i6. I'm currently driving the second one. I've really enjoyed the exhaust note of both, and feel it's about perfect, aside from the crackling on deceleration. I've been really surprised how quiet each truck has been, which doesn't make sense with the glasspacks.
Old 02-25-2021, 11:03 PM   #13
bigmoe
bigmoe's Avatar
Drone is at lower rpm. It's a loud and echoey hummmm. Lol I'm trying to figure out the best way to explain. Maybe try youtube exhaust drone.
Old 02-26-2021, 08:25 AM   #14
Acregger
I am in the same spot, dont want the drone. I like to hear it and it have a good sound but not terribly loud. I think I may just have a guy do custom exhaust and hope for the best.
Old 02-26-2021, 10:02 AM   #15
Custom 68
Custom 68's Avatar
Borla mufflers can be expensive but I have used them and recently installed one on my newer truck. They have a nice rumble on startup and idle but seem to calm down when driving. They will roar when you get on them.
I had this on my 68 but with the turbo and resonator it was quiet. I am trying something different on it, the turbo changes it significantly.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-05-2021, 09:29 AM   #16
nsb29
nsb29's Avatar
Had exhaust put on my truck yesterday went with the flow master 50s not impressed much louder than I expected from what I had heard but what I dislike the most is when you rev it up it has a crackle when you let off Sounds like sh t
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 03-07-2021, 09:44 AM   #17
Acregger
That worries me too, I dont like that crackle either.
Old 03-16-2021, 01:37 PM   #18
Steve Cole
Funny you mention the crackle. I just had my exhaust done due to the LS swap and now I have the crackle. I never had it before when i had the SB 350 and I am using the same Magnaflow mufflers I used then. Three differences between the old and new exhausts- the old system had an "X" pipe installed where as now it is just true duals and also the mufflers are further towards the rear of the truck than before and lastly I am running mid-length headers now and had long tube headers before. My system is actually quieter than before but when you get in the gas it sounds like crap. Is your exhaust a true dual setup?
Steve Cole is offline   Reply With Quote
Old 03-16-2021, 06:03 PM   #19
nsb29
nsb29's Avatar
I have the cast manifold that came with the motor which is from a Pontiac G8 I believe similar to the Camaro cast manifolds from there is 2 1/2 inch exhaust back to the mufflers and then exit behind the rear wheels I did not use an H Or X pipe driving down the highway it really isn’t that loud but going through the gears it’s louder than I wanted I am considering installing two small glass packs behind the mufflers in a straight area about a foot and a half from the end I also wondered if it was because I did not install an H or X pipe ????? I also wondered if it was the brand I bought and maybe I should have bought magnaflows but if you’re having the same problem that’s obviously not it if you figure out something before I do post it I’ll do the same
Old 03-17-2021, 10:48 PM   #20
aknovaman
GM 3800 v6 cars have resonators between the cats and the muffler. Removing them creates a terrible rasp and fart noise at idle. They are essentially a perforated glass pack design thats straight through.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 03-18-2021, 08:37 AM   #21
nsb29
nsb29's Avatar
so basically it’s a small glass pacts thanks sounds like a solution
Old 03-20-2021, 02:27 AM   #22
Gregski
Gregski's Avatar
just wanted to share some pics of me ditching my DroneMasters and going with some Magnaflows, honestly still loud without cats, these were hacked out of some GTO
rig is a 4.8L LR4
I built my dual exhaust out of stock Tahoe and Suburban exhaust pieces from Pick N Pull by reversing the passenger side to the driver side, here is a link to the build post if anyone wants to take a peak
https://67-72chevytrucks.com/vboard/...postcount=6059
Gregski is offline   Reply With Quote
Old 03-23-2021, 07:06 PM   #23
jweb
jweb's Avatar
I have Magnaflows similar to these on my '51 (LS1) and it sounds pretty good.
https://www.magnaflow.com/products/1...rmance-muffler
When I had the exhaust made, they recommended two things.
1: Keep the mufflers close to the headers. They said this would reduce the drone because the further you let the exhaust travel before passing through a muffler the more drone you will have. Due to the sound waves bouncing around in the pipes.
2: Run the pipes all the way to the back. This way, even if it's a little loud it will be further away from you.
Adding a resonator before the muffler may be a good fix for this problem.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 03-24-2021, 11:57 AM   #24
Steve Cole
Thanks for the info jweb. My issue isn't really drone, it is that it just sounds like crap. I think nsb29 doesn't like the sound of his either.
Old 03-24-2021, 06:10 PM   #25
nsb29
nsb29's Avatar
You got that right
I’m about ready to replace them with a pair of glass packs LMAO
