![]() Join Date: Jun 2000
Kick panel vent handle in '68
I believe this is the factory kick panel vent handle for a '68 (see pic). Sounds like they changed it to a round knob in '69. I can't make sense of why the early ones were designed this way. If it spins easily on the rod, it's very awkward to use. I'm not even sure which direction it's supposed to be turned on the rod. Anybody have some background behind this design? I never got to use one when new, so maybe it made more sense back then?
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
Re: Kick panel vent handle in '68
my 67 is like that too i wonder the same thing
I have a '68 C10 and '68 C20 and both of them have the same ones that you posted.
Old member
My 67 Ramp truck has them. I just think thats how the molded them back then.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I didn't realize the later ones were different! You learn something new every day here. My guess is the later design was 10 cents cheaper to source they went with that design.
I saw a news article many years ago how automotive designers tweak every last cent out of their production costs. 50 cents per unit equates to hundreds of thousands of dollars of cost savings over millions of units produced or something like that.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
![]() Join Date: Aug 2019
Toms68cst, you are exactly right. Styling, cost, vender quality all go into making a car or our case a truck. GM doesn't spend a penny they don't have to. So when you say i'm not going to put that part back on, remember it was designed and installed by GM for a reason.
#7 | |
Old member
For my 71 C-10 I went to pickclick and typed in billet knobs, it will pull up all kinds of knobs. I put a whole set in the 71. The dash and the vents all match.
