03-02-2021, 01:43 PM | #1 |
motor swap mount question
Hello,
1965 c10 inline 230 (Bad motor been bored over too many times) I was finally able to source a replacement motor for my 65. The motor is from a 1978 c10 inline 250 (Good running motor) Forgive my lack of understanding of motor mounts but I am a bodywork guy trying to learn. The mounts look very different. With the 78 mount sit on the stock perch? Will the 65 mounts fit the 78? What is the best way to mount this motor? thanks |
03-02-2021, 08:06 PM | #2 |
Re: motor swap mount question
Unbolt the 65 mounts from the block and bolt em to the new motor.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-02-2021, 08:11 PM | #3 |
thanks, looking at the block its the same pattern so that makes a lot of sense.
next question.... does anyone have a pic of how the mounts go on? Orientation/bolt wise? Ive ordered me factory assembly manual but waiting on the post office. I took everything about down to frame. So now just which direction everything faces?? |
03-02-2021, 09:26 PM | #4 |
I found the answer in searching the forums here:
http://67-72chevytrucks.com/vboard/s...d.php?t=523133 thanks all |
03-02-2021, 10:25 PM | #5 |
Glad you got it sorted. My '64 had a 230 and a 350 bolted with new motor mounts without changing anything. In case you go that route later. I think 63 on same mounts for V8 and I6?????
03-03-2021, 01:36 PM | #6 |
For 63-66, the v8s and the 230 and 250 straight 6s used the same frame stands. The 292 straight 6 used the same driver's side stand, but the passenger side was different. GM used different stands for straight 6 or v8s on the 67-72 trucks
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-03-2021, 02:23 PM | #7 | |
Thanks for clarifying! Someone told me they were the same 63 on. |
03-06-2021, 11:39 AM | #8 |
OK think I found the answer to my motor mount fiasco ,my drivers side is allmost lined up ,but the pass. side is way off. This truck must of had a 292 in
it at one time.Bought it with the 350 installed and have been finding all kinds of suprises. The towers are welded to the frame plus I found the drivers mount allso has a 1/2" spacer between the mount and tower
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
