03-10-2021, 06:53 PM | #1 |
Cranks on run and crank/gauge question
At it again, I pulled my old harness and putting in a new bp automotive harness, I was hooking up the starter and solenoid wires, now it cranks in the run and crank position. Has anyone else encountered this problem? I did have a issue with the neutral safety switch before. I havnt fully wired up the gauges and inside of my cab. This is kicking my butt.
Second question I just bought a autometer 7004 lcd gauge cluster, I was running autometer electric gauges before, are those sending units still the same?
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
03-10-2021, 09:22 PM | #2 |
Re: Cranks on run and crank/gauge question
might check the wire connections for the switch sound your your switch on and crank are touching or connected wrong..
03-12-2021, 08:19 AM | #3 |
You might also check your wires on the plug to make sure they’re in the right place my headlight switch from them came miss wired
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
