Old 03-12-2021, 10:00 AM   #1
Android04
Android04's Avatar
Front brake Caliper Help
I have a 1985 C30 and just installed a 6" drop in the front with 3" drop spindles and springs. While rebuilding the entire front end, I went ahead and bought all new brake components including calipers. Now the issue is I can't get the new brake calipers to fit these spindles to save my life.
I've tried to even install them without pads and still no luck. It's almost as if I need to grind one or other down for it to fit, and not a fan of that AT ALL.
They are both made for clip on calipers. Here are the parts ordered:
WST-13600 - Western Chassis 3" Drop Spindles
Part # 18-4167 - Wearever Unloaded Caliper
Any suggestions, tips, etc.?
Here is my new project/baby fresh out of paint. I've been wanting one of these for over 15 years.
Android04 is offline   Reply With Quote
Old 03-12-2021, 10:18 AM   #2
v30crewcab
v30crewcab's Avatar
Re: Front brake Caliper Help
gonna need pics of the non-fitting parts if you want good advice. you're either doing something wrong, or they were machined wrong. show us how they're not fitting.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 03-12-2021, 10:22 AM   #3
Android04
Android04's Avatar
I will get pictures today. To try and explain it better the caliper does not fit the spindle. I can slide it in at the top grove on the caliper/spindle and the amount of clearance for the bottom to slide into place before sliding/beating in the bracket and bar to sit correctly in the lip is not even close.
But I will get pics soon, I know it's kind of hard to picture. Also never owned a truck with clip on calipers. So much fun
Old 03-12-2021, 10:35 AM   #4
Android04
Android04's Avatar
Pictures:
So the top is set inside the lip (Unloaded no pads) and you see how far off the bottom is from sliding into the bottom grove. Even if I slide it in the bottom first have the same issue at the top.
Hope this helps.
Old 03-12-2021, 11:59 AM   #5
mongocanfly
mongocanfly's Avatar
Do you still have your old parts to compare with..?..
Nice looking square..!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-12-2021, 12:57 PM   #6
Android04
Android04's Avatar
Thank you.
Unfortunately all the old parts are gone.
Old 03-12-2021, 06:31 PM   #7
sweetk30
sweetk30's Avatar
None of that spindle mount for brakes looks like the C/K bendix brake mounts i have seen for our trucks .
I will check the pics again when i go out in the shop later . On my phone now .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-12-2021, 07:18 PM   #8
sweetk30
sweetk30's Avatar
o.k. so on my 40" shop tv / computer screen i still say there messed up on the spindle side . i think you need to make a call to them and ask . or better yet drop a email with pics and give your phone no# for them to call you .
Old 03-12-2021, 10:46 PM   #9
v30crewcab
v30crewcab's Avatar
need to measure the distance on a stock spindle, and check against the dropped one. looks like they are machined way to big on the opening. very strange.
71 longbed 5.3 4l80
