Old 03-16-2021, 08:43 PM   #1
Mathew21
Mathew21's Avatar
4wd rear axle direct bolt in in 2wd Pickup?
I have 2003 2wd 1500 Silverado needs a rear axle. I'm going to the local u pull to get one are the 4wd axles direct bolt in or do I need to find another out of a 2wd?
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 03-17-2021, 02:54 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: 4wd rear axle direct bolt in in 2wd Pickup?
The spring perches and shock mounts should be the same.
Get one with the same gear ratio. You can re-program your PCM for the new ratio with a tuner and maybe the ABS controller with a Tech2 (I'm not positive you can do the ABS without a new CAL from GM) but why make it more difficult than it needs to be.
Look on the SPID in the glovebox for the gear codes.
https://www.crawlpedia.com/rpo_axle_codes.htm
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-17-2021, 08:17 PM   #3
Mathew21
Mathew21's Avatar
Thank you I appreciate the information.
