1969 K10 clutch options
Looking for advice on a clutch kit. I currently have a SACHS 12" kit in the truck and the pedal is very heavy ( wife has an issue driving the truck ). Just wondering if anyone had experience with an aftermarket kit that would reduce pedal effort. The truck has a new small block in it with the SM465 trans and doesn't get abused so I am not concerned about maximum holding power.
![]() Join Date: Mar 2003
Re: 1969 K10 clutch options
3 finger or diaphragm clutch??. Diaphragm clutches are easier with the same clamping pressure. If she is having problems with the diaphragm, you may have to go hydraulic
All about them K’s
![]() Join Date: Jun 2014
I used a LUK 12” kit from Napa in my K20. Couldn’t be happier with it. It’s supposed to be the same as the stock clutch. I’ve got a hydraulic setup in my truck so it’s got a light pedal but I don’t see why it would be heavier than a stock clutch with a mechanical setup.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
