03-26-2021, 07:37 AM | #1 |
Rear leaf helper springs
Looking suggestions on rear leaf spring load helper springs. My 04 Silverado Crewcab sags more than I like when loaded....
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
03-26-2021, 01:51 PM | #2 |
Re: Rear leaf helper springs
Are you over the GVW ?????
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
03-26-2021, 06:33 PM | #3 |
Just looking for recommendations....
03-26-2021, 08:11 PM | #4 |
I would inspect your springs, pins, brackets, attachments, etc. thoroughly first and replace anything broken..
if all you find are worn or sagged springs, they should be fairly reasonable $ to replace and you can restore factory capacity/height or adjust to taste.. we replace springs in fleet vehicles frequently, either ordering oem or local suspension shop beefs a set up for special needs.. I have air lift springs on my 02 for added capacity and they're plumbed individually for leveling when necessary.. original set last almost 15 years, on second set now and springs are healthy.. money well spent for smooth level towing.. good luck! 2200lbs of concrete
I started out with nothing - and I still have most of it |
03-27-2021, 08:39 AM | #5 |
Well I sure aint pulling/loading that much. Just looking for a quality helper springs. Nothing is worn or broken....
03-27-2021, 09:44 AM | #6 |
laying low
I installed a pair of Air Lift bags to the rear of my 06 1/2 ton crew cab for just a bit of leveling when hauling/towing. For a couple hundred bucks it is a worth while addition and Air Lift has a good rep. I bought mine from Summit.
