03-31-2021, 11:25 PM | #1 |
Radiator air flow
I have an LC9 in my 70 ss. The extra cam timing stuff on the front gives me no room for a puller fan. The back of the engine is less than an inch from the firewall so I can't move it rearward. I have a large Spal pusher in front of the AC condenser.
There is quite a gap between the radiator and the condenser and a lot of the air pushed by the fan escapes before going through the radiator. I am installing a new crossflow radiator and was wondering if there was some material (sponge, etc.) that I might use to seal the gap. While it hasn't run hot, once the fan turns on like at a stop light it doesn't quit until I am roiling again. Atlanta area gets pretty hot in the summer. Thanks |
03-31-2021, 11:56 PM | #2 |
Re: Radiator air flow
Yes. Hit up your local hardware store. If your fan doesn't push the most CFM possible, I'd upgrade it the max you can find since pushers w/o a shroud aren't as efficient. Electric fans running at idle when the engine is up to temp and shutting off when you are moving is normal. Oh yeah, since water cools better than antifreeze, I'd be running 80% water 10 months out of the year there.
04-01-2021, 01:20 AM | #3 |
Always use 50/50 mix . No matter if you live in Seattle or Miami
https://knowhow.napaonline.com/water...ze-safest-car/
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
04-01-2021, 10:12 PM | #4 |
04-01-2021, 11:35 PM | #5 |
My understanding is that plain water releases it's heat best but the coolant/antifreeze raises the temp of boiling. I've heard a product called water wetter also helps. Never tried it myself
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
04-02-2021, 12:09 AM | #6 | |
20' Daredevil (Ret)
I tried Water Wetter many years ago in an old Miata we owned. I did not notice any difference....
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
04-01-2021, 01:21 AM | #7 |
Putting a larger fan in will not solve your problem. You need to seal the open area around the condenser to the core support so air is directed through the radiator. A metal shroud would be best. You could use foil tape for a temp fix to see if it works. People run into a similar problem with dual pull fans running only one at a lower temp. A lot of the air is pulled from the engine compartment through the static fan instead of through the radiator.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-01-2021, 09:05 AM | #8 |
Old member
They sell a black foam that works great for this. I would also recommend the grille to support covers to force more air through.
I can a test to sealing off the radiator and forcing the air through it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-01-2021, 11:49 AM | #9 | ||
"I ain't nobody, dork."
"70 ss"?
Gary
04-01-2021, 12:16 PM | #10 |
Must be a super six Gary!
04-01-2021, 10:32 PM | #11 |
GASoline71 & geezer#99
70 ss - 70 step side Must be a super six Gary! - LC9 is an LS 5.3 for trucks |
04-02-2021, 09:15 AM | #12 |
I learned a long time ago the effects of running water in an aluminum engine. The manufacturers will void your warranty if you don't use antifreeze.
04-02-2021, 09:29 AM | #13 |
Only time to run straight water is on the track . Southern temps you can get by with 70/30 up here where I live 50/50 minimum.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
