![]() Join Date: Aug 2014
Steering Column Intermediate Joint Thingie Identification
hi guys I don't even know where to start with this thing, can someone please tell me what it is called and can it be replaced with a U joint of some kind, I don't see the shaft being D shaped so I don't know what to do
worst case scenario I just need that rubber boot or gator what ever it is called and I can repack it with some Crisco grease and send it Last edited by Gregski; 04-06-2021 at 06:42 PM. |
Re: Steering Column Intermediate Joint Thingie Identification
so I guess that thing is called a coupling, and I found this thread on something similar
Rebuild a steering shaft grease boot however this video has me wondering if we are missing a spring Steering Shaft Coupler Rebuild | Pot Joint Boot replacement | Vega EP19 |
I believe it is called a pot joint. Looks like the rubber master cylinder cap may work well, but I haven't tried it. Those joints are actually a good thing, because it is a slip joint and allows movement between cab and frame without binding the steering shaft.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#4 | |
and I ordered this kit for the rubber boot really |
I just watched the video, it's quite good. As for the spring, I don't know for sure if yours came with one or not. But, I don't think it would matter if you don't have one. The spring would just preload the joint, maybe to keep it from rattling. Would not be a function or safety issue without it. I might order one of those boot kits, glad you found that.
