power steering pump lines
I have my original gearbox but threw the lines out with the original motor (inline 6). I now have a 4.8 installed; instead of buying a new set of expensive hose's can I just order the original hose ( I only need one ) and attach it to the new LS power steering pump. i believe they sell an adapter.
Re: power steering pump lines
The l31 and tbi ps pumps you remove the oring fitting from the pump and use no oring fitting from your old ps pump
i am on the understanding ls pumps are the same i have not varified this yet as both ls motors are still in there original trucks and have not progressed to the point yet to pull one out |
![]() Join Date: Jul 2000
The pump on the 4.8 engine probably uses metric hose fittings.
I had just the opposite problem when I used an older pump with SAE pressure fitting on an 82 C10 metric box. Ended up buying a metric-to-SAE adapter and making this pressure hose. Probably overkill, because an truck hose shop can make a rubber one for you.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
the difference is non o ring fitting and o ring fitting
![]() Join Date: Sep 2007
i used my original lines from my sbc on my ls pump no problem
1967custom |
