Old 05-20-2021, 11:34 PM   #1
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
wanted 8000 RPM tach Lens pic
Anybody out there have a pic of a 8000 RPM lens. I'm looking to have a decal made up to replicate the #'s. Post the pic in this thread please.
Thanks, Michael
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 05-22-2021, 01:01 AM   #2
Accelo
Accelo's Avatar
Re: wanted 8000 RPM tach Lens pic
Maybe this will work?
Accelo is offline   Reply With Quote
Old 05-22-2021, 09:08 AM   #3
CarlsLQ9SS
CarlsLQ9SS's Avatar
Is your truck LS swapped? Did you have any trouble making this tach work with it? Thanks
CarlsLQ9SS is offline   Reply With Quote
Old 05-22-2021, 09:16 AM   #4
CarlsLQ9SS
CarlsLQ9SS's Avatar
Here is some as well
Old 05-22-2021, 10:03 PM   #5
Canuckvetter
That’s what I need. Thanks!
Old 05-23-2021, 07:18 AM   #6
CarlsLQ9SS
CarlsLQ9SS's Avatar
Your welcome!
Old 05-22-2021, 03:30 PM   #7
Accelo
Accelo's Avatar
Yes it has an LS1 in it. However I do not have it running yet. I did help my friend with his LS3 install in his Camaro. He just added a resister to the circuit and his factory tachometer worked fine.
https://www.youtube.com/watch?v=FS7aRfYkFAQ
This link should help.
Rick
Old 05-23-2021, 07:17 AM   #8
CarlsLQ9SS
CarlsLQ9SS's Avatar
Rick
Thanks for the info Rick!
Carl
Old 10-10-2023, 06:28 PM   #9
pjmoreland
pjmoreland's Avatar
Did you end up having a decal made?
pjmoreland is offline   Reply With Quote
Old 10-11-2023, 06:54 PM   #10
Canuckvetter
Not yet pjmoreland. I got a lens off CarlsLQ9SS, but I'm not 100% thrilled with it now that it's in the truck. The diesel tach increments do not line up with the numbers, which sets my OCD into a frenzy lol. Also all the aftermarket lenses I have seen, the numbers and letters are thiner than the originals. Maybe once the truck goes away for the winter I will get a reverse decal made so I can paint the words and numbers on a new lens. Also I have a KPH Speedo so I would like to replicate the set up Member Chewy has with the Tach,Vac,KPH,Speed warning, adding the 8000 RPM Tachometer,
https://67-72chevytrucks.com/vboard/...1&d=1697063069
https://67-72chevytrucks.com/vboard/...1&d=1697063193
Old 10-11-2023, 07:57 PM   #11
chewychevy67
That looks sweet. I agree the aftermarket lenses just don't cut it . Some look blueish as well.
chewychevy67 is offline   Reply With Quote
Old 10-12-2023, 03:35 AM   #12
pjmoreland
pjmoreland's Avatar
I removed the 5k lens from my gauge cluster this evening and scanned it. I am working on tracing the outlines of the numbers and moving them to the correct locations for an 8k tach. I'm just going to do 0, 10, 20, 30, etc. around the outer perimeter because I think the smaller numbers in the inner circle look out of place compared to the original tach. I'm going to copy and shrink the 6, 7 and 8 characters from the speedometer. I also plan on tracing out the VACUUM label.
Old 10-12-2023, 11:33 PM   #13
pjmoreland
pjmoreland's Avatar
I finished tracing out the perimeters of the characters. The 6, 7 and 8 characters are copied from the speedometer. I used CAD software to set the spacing of the numbers. I still need to trace out VACUUM.
Old 10-13-2023, 12:13 AM   #14
pjmoreland
pjmoreland's Avatar
Here's the VACUUM text.
Old 10-13-2023, 09:28 PM   #15
pjmoreland
pjmoreland's Avatar
I went to a printing shop here in town to ask them about printing the numbers on my gauge lens. They have a direct printer that should work. They showed me some samples, and it has super fine resolution. They can match the light green color of the original numbers, too. I emailed them the 8k tach numbers I drew up, so we will see what they say. I polished the stock markings off of two lenses I've got.
Old 10-20-2023, 04:04 PM   #16
pjmoreland
pjmoreland's Avatar
An 8k tach I ordered arrived today. My layout for the numbers lines up well.
In my opinion, Counterpart did a lousy job of locating the tach numbers on their 8k lens, and the font is totally wrong.
I heard back from the print shop, and unfortunately their printer is down right now. They are estimating two weeks until it is repaired. I contacted another shop in a neighboring town, and theirs is down, too. I'm gonna keep looking.
Old 10-20-2023, 07:56 PM   #17
Canuckvetter
That’s awesome what you did. I would purchase a template should you decide to share. I have a template of the KPH speedo I got off member 68 50th from Sweden that I would like to print up as well.
What you have done so far looks great!!!
Michael
Old 10-20-2023, 11:21 PM   #18
pjmoreland
pjmoreland's Avatar
Michael
I'm looking into getting the numbers printed directly onto the lens. How did 68 50th do it?
Old 10-21-2023, 10:24 AM   #19
Canuckvetter
Mats had stickers made up that stuck to the inside the lens. White only.
Old 10-21-2023, 10:26 AM   #20
pjmoreland
pjmoreland's Avatar
Were the stickers white printed on a clear backing, or were they die-cut out of white vinyl?
Old 10-21-2023, 09:24 PM   #21
70STOVEBOLT
70STOVEBOLT's Avatar
My daughter can make stuff like that on her Cricut machine
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 10-21-2023, 09:57 PM   #22
pjmoreland
pjmoreland's Avatar
Would she be interested in looking at my file to see if she'd want to make it?
Old 10-31-2023, 05:09 PM   #23
pjmoreland
pjmoreland's Avatar
I received the vinyl stickers from your daughter, and they look great! I applied one to a lens just now. A couple of the numbers peeled up when the unneeded vinyl was being removed, so those numbers had to be put back down manually. Overall, it looks great, in my opinion. I'd like to explore the possibility of getting the stickers made in a light green that would more closely match the original color.
On a side note, I am still talking to a print shop about direct-printing the text onto the lens. They are going to be printing me a sample.
Old 10-21-2023, 11:55 PM   #24
pjmoreland
pjmoreland's Avatar
I looked up cricut machines. Looks like they are somewhat affordable for home use.
Old 10-22-2023, 06:04 PM   #25
70STOVEBOLT
She made the wording for all the signage for her wedding last weekend, and she made center cap decals for my truck. I will ask her if she’s interested. What type of file is it?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
