Old 05-22-2021, 08:55 AM   #1
Bobbysgmc
speedometer needle
While hooking up my speedometer the needle went to the 6 o'clock position.It still works but only goes up to the20-30mph position when driving.Odometer works.How do I reset the needle to the zero mph setting?
Bobbysgmc is offline   Reply With Quote
Old 05-22-2021, 09:04 AM   #2
CarlsLQ9SS
CarlsLQ9SS's Avatar
Re: speedometer needle
I think you will have to take the gauge out and reset the needle to the "0" position by taking the needle off and pressing it back down with your thumb, if that makes sense.
CarlsLQ9SS is offline   Reply With Quote
Old 05-27-2021, 08:40 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
The speed cup has a stop so you have to set the needle at 10 mphand give it a slight push with you thumb while twisting gentle counterclockwise toward zero.
It is a feel thing and will take a few times to reset it. you can remove the neelde by turning counter clockwise and giving a slight pull up from the round part of the needle. Try and twist the needle as close to the base as you can. .
To access, pull the 8n perimeter screws and split the cluster.
hope this helps.
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 05-27-2021, 09:21 PM   #4
Bobbysgmc
Smile Re: speedometer needle
Thanks,Got it reset.Turned the needle against the high mph stop and turned needle forward.Took a few tries to get it set.
