05-26-2021, 01:59 PM | #1 |
Hood emblem gasket 56??
Im getting ready to bolt on my hood emblem. I have searched everywhere and cant find a gasket for a 56 emblem. Did they not use gaskets after 55??
Really having a hard time bolting it directly to my new paint. If nothing else I will use some 3M clear tape but would rather use a gasket. Any insight would be appreciated! |
05-26-2021, 03:12 PM | #2 |
Re: Hood emblem gasket 56??
my 57 came sans emblem. I would check with an autobody supply shop and see if they have some thin gasket material, something that is a closed cell foam would be good because it doesn't sponge water. possibly some emblem tape? possibly some thin foam like used under a wall in a basement? possibly a thin cork sheet from a hobby shop or a cheap bulletin board? thn rubber sheet from a plumbing store or plastic supply outfit? some thin eva foam?
05-26-2021, 10:19 PM | #3 |
That’s probably the route I will have to go. Build my own. Thanks for the suggestions!
05-27-2021, 03:30 PM | #4 |
Looks like in the factory assembly manual there was none for the '55. Not sure for a '56 to '57. I don't recall one on my '57.
05-27-2021, 05:08 PM | #5 |
Even though my AD hood emblem came with a gasket, I chose not to use it. My reasoning was that it would trap moisture that could eventually produce rust.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 05-27-2021 at 05:24 PM. |
05-27-2021, 08:23 PM | #6 |
i can't say i've ever seen a gasket on any trim
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-28-2021, 11:37 AM | #7 |
I believe I used nylon washers behind the emblem to help keep pressure off the paint. No gasket.
