06-11-2021, 12:05 AM | #1 |
Headlights, dash lights & front side markers not working
All three just stopped working. After they stopped working I did a ground up rebuild on the front end and installed a new front wiring harness so I know it’s not up there, I also put in a new headlight switch, didn’t fix the problem either, checked the wiring plug to the switch and it has power.
Is this a ground problem? The parking and tail lights are part of the switch and they work. Any insight would be greatly appreciated. |
06-11-2021, 11:53 AM | #2 | |
Re: Headlights, dash lights & front side markers not working
06-11-2021, 07:51 PM | #3 |
If the park and tail lights are working it isn't a ground problem.
06-11-2021, 10:41 PM | #4 |
06-11-2021, 11:33 PM | #5 |
It's your headlight dimmer switch.
06-12-2021, 01:31 AM | #6 |
If you have power to the head light switch ( big red wire ) then it is the head light switch that has gone bad.
06-12-2021, 06:33 PM | #7 |
06-13-2021, 12:11 AM | #8 |
