12-23-2003, 01:06 AM | #1 |
Designated A-hole!
Uh-oh!
I go to drive home from my folks and everything electrical on my truck flickers including the engine. Happened two or three times in first 5 or 10 miles then stops. What do I need to be checking? The battery cables are clean and tight.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
12-23-2003, 01:47 AM | #2 |
Are you externally regulated? I have had regulators do that to me. Time for a internal conversion. . . .
12-23-2003, 01:55 AM | #3 |
Designated A-hole!
That's what I am thinking. The timing could be a little better tho!
12-23-2003, 05:05 AM | #4 |
flicker
Make sure the wires are tight at the fender terminal by the battery.
12-23-2003, 11:14 AM | #5 |
Check the negative ground from the battery to the block--block to the firewall.
12-23-2003, 11:33 AM | #6 |
Make sure that your alternator bracket bolts are tight.
12-23-2003, 12:28 PM | #7 |
Designated A-hole!
All cables and brackets are good and tight. How do I test the regulator?
12-23-2003, 01:02 PM | #8 |
They are so cheap that I never test them. I just replace, and if it doesn't fix the problem then I know that wasn't it.
