Old 06-22-2021, 12:02 AM   #1
68gmcdude
Brake pedal goes to floor
Hi All... Suddenly my brake pedal is going to the floor. My '68 GMC has manual drum brakes all the way around. The rear reservoir was low on fluid. Passenger rear looks damp, maybe wheel cylinder is leaking? Could master cylinder be bad? Just air in the line? What steps should I go through to find out exactly what's wrong? Thanks!
68gmcdude is offline   Reply With Quote
Old 06-22-2021, 04:25 AM   #2
custom10nut
custom10nut's Avatar
Re: Brake pedal goes to floor
If you pedal goes down but the brakes still work, and the fluid level stays even, then that means your MC is Bad.
What you described is a bad cylinder on that rear wheel.
Since your front half of the MC stays full, that says nothing is leaking, up front.
When you pull that suspected drum apart you’re gonna find the diaphragms are bad and leaking.
If the cylinders are originals then it’s time to just replace them all (it is 53 years old, after all), and while your at it, possibly put a new set of shoes on.
It sounds like a lot of work (it’s really pretty easy, but then you’re not going the be revisiting the same problem on another wheel in the near future
custom10nut is offline   Reply With Quote
Old 06-22-2021, 08:29 AM   #3
68gmcdude
Thanks for the reply custom10nut. My plan is to replace all of the wheel cylinders. If one went the others are probably not far behind. Thank you for clarifying the MC issue. I wasn't sure about that. All of the pads don't look bad, but I might as well replace them and be done with it. I'll keep you posted.
Old 06-22-2021, 09:04 AM   #4
custom10nut
Take a good look at all the components when you take them apart, and if you’ve had the truck for a while and have never replaced them, it’s time
One word of advice I have for you.
If yo start in the rear, take both drums off, but disassemble and reassemble one at a time.
This allows you to have a reference to look at to be sure you have it assbled correctly.
Then when you’re don’t with all four corners, get some help to bleed the air out (it shouldn’t be much) starting with the drum farthest from the MC.
Old 06-22-2021, 09:05 AM   #5
weq92f
weq92f's Avatar
If you can pump on the pedal and get a higher resistance point ( firmer pedal ), you may also be fighting a MC problem.
I drove like this on an all drum '68 for a long time. Every time I needed a bit more pedal I'd just pump the brakes a bit to get it! Dangerous? Maybe.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-22-2021, 10:30 AM   #6
68gmcdude
So looking at brake shoes online, looks like there are three different sizes for my truck... 11" x 2.06, 2.07 or 2.82. I'm guessing this is the width of the shoe pad? I measured my current pads at basically 2.06 with my micrometer. I'm assuming this is what I should order? Picture attached.
Old 06-22-2021, 04:26 PM   #7
Happy_dan
Happy_dan's Avatar
Just an FYI - The bleeding sequence on my C-20 was not the furthest because of the way the brake lines run. Search this site for the right sequence because I can't remember and don't expect to need to do it again for a while.
I believe it's usually passenger rear because it is the furthers, but on my truck it was drivers rear first, then passenger rear then passenger front and finally drivers front. But I could be mistaken.
Happy_dan is offline   Reply With Quote
Old 06-22-2021, 06:04 PM   #8
MySons68C20
MySons68C20's Avatar
Take a pic with your phone before removing springs etc......big help upon reassembly. I prefer back bleeding....bought a cheapy NAPA kit and it works great.
MySons68C20 is offline   Reply With Quote
Old 06-22-2021, 10:13 PM   #9
68gmcdude
I have another question. My front drums have the hubs attached to the drums. Looks like there are no replacements with this setup. I only see new drums without the hubs. Do I buy just the drums, have someone remove the hubs from the old drums, then add them to the new drums? I appreciate everyone's help!
Old 06-22-2021, 10:50 PM   #10
Wrenchbender Ret
There are 3 rivets holding the drum on. Cut the heads off the rivets & remove the drum from the hub. You do not have to replace the rivets. The lug nuts hold the drum on.
George
Wrenchbender Ret is offline   Reply With Quote
