Old 06-24-2021, 11:36 AM   #1
Shock_Me
Shock_Me's Avatar
AC leaking
Hi all. I haven't been here in years, so it's great to post something again!
The last two summers I've had to get my refrigerant topped up in the Blazer. Obviously its leaking out somewhere, but it's not obvious to me from where lol. Is there a common area I should be looking like the compressor seal maybe?
thanks in advance, and it's great to be back here!
Shock_Me is offline   Reply With Quote
Old 06-24-2021, 02:10 PM   #2
truckster
truckster's Avatar
Re: AC leaking
How old is your compressor? Common leaks are the compressor seal and anywhere there's an O-ring.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 06-24-2021, 02:39 PM   #3
Ziegelsteinfaust
Re: AC leaking
Also hose connections or crimps.
This is way auto guys use dye. This way when it leaks you cam use a black light to find the actual leak.
I do commercial, and we use it to prove a coil is bad.
Ziegelsteinfaust is offline   Reply With Quote
Old 06-24-2021, 02:42 PM   #4
Ziegelsteinfaust
Re: AC leaking
Forgot to add, but you maybe able to see oil in the area the leak is.
Old 06-29-2021, 10:21 PM   #5
70cst
70cst's Avatar
Re: AC leaking
This is the best way ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-24-2021, 09:09 PM   #6
Shock_Me
Shock_Me's Avatar
Re: AC leaking
Thanks for the replies! I’ll start looking for these clues. Pretty sure the compressor is original.
Old 06-27-2021, 04:19 PM   #7
hemi43
hemi43's Avatar
Re: AC leaking
What refrigerant are you using? If it's 134A, it will always leak because that system is not designed for it. 12A is a better choice for retrofits.
hemi43 is offline   Reply With Quote
