Old 06-28-2021, 12:31 AM   #1
72 k15
72 k15's Avatar
Daily a 71-72 k10/20
Anyone out here daily a 71-72 k10/20 I will occasionally drive on the interstate about 300 mile round trip, speed limit is 75mph so I’m assuming I’ll need overdrive. How’s reliability with a stock truck? How is starting in the winter? It gets to be pretty cold up here -20 isn’t uncommon.
1959 GMC 100 3 on the tree 270.
1968 GMC k2500 Stepside
1972 Chevy Monte Carlo Custom.
72 k15 is offline   Reply With Quote
Old 06-28-2021, 08:56 AM   #2
71K1500
Re: Daily a 71-72 k10/20
My son uses his daily year round. Its a 70 GMC 4x4. Motor is a 5.7 with tbi from a late 80s truck with 700R4 trans. No problems but he does plug it in during cold spells.
I had a 72 4x4 when he was little that I used all year. It was original with a quadra jet carb.
As long as maintanance is kept up I dont see a reason to not use them.
Jeff
71K1500 is offline   Reply With Quote
Old 06-28-2021, 12:49 PM   #3
72 k15
72 k15's Avatar
Jeff
The 3 main things im worried about would be reliability, cold starting, highway driving. I dont think im to worried about the cold now or highway as I would drop a overdrive unit in.
Old 06-28-2021, 01:14 PM   #4
truckster
truckster's Avatar
I daily drive my 72 Blazer. It starts every time and gets me wherever I'm going.
As far as overdrive, what engine/transmission/rear end/tire size are you running?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 06-28-2021, 01:42 PM   #5
titan1587
There’s a thread about 2 posts away with exact same question
2002 Duramax I love
1971 k10 4x4 longbed 350/350/205 all original
titan1587 is offline   Reply With Quote
Old 06-28-2021, 02:27 PM   #6
72 k15
72 k15's Avatar
Well, im trying to figure out if I would need one and im thinking I will, speed limit is 75 and traffic goes 80. Im basically debating selling my 02 2500HD and buying a 71-71 4wd for a daily and trying to see if it is feasible for what I do. I really only would need to drive highway 1 time a year for hunting 120 miles away.
Old 06-28-2021, 07:04 PM   #7
truckster
truckster's Avatar
I have a 350/350 with 3.73 gears and 33" tires. It runs fine at 80.
Old 06-28-2021, 07:18 PM   #8
72 k15
72 k15's Avatar
At 3000 RPM? can’t imagine that’s decent for the motor or gas milage.
Old 06-28-2021, 08:35 PM   #9
jocko
jocko's Avatar
Yes that combo is a hair over 3000 RPM at 80. The tires help, stock-ish 30" tires would be closer to 3300 rpm.
3000 on the highway wasn't that uncommon back in the land before overdrives - but now that we're used to cruising at 2100 RPM, 3000 feels like it's screamin. Doesn't really hurt the engine, per se, but it does affect fuel economy of course.
Old 06-28-2021, 11:04 PM   #10
72 k15
72 k15's Avatar
Interesting, I suppose I don’t normally drive a lot of intestate maybe a 1000 miles a year max. What does she get for gas milage at 80 and 3000rpm?
Old 06-28-2021, 11:37 PM   #11
truckster
truckster's Avatar
A small block Chevy - any engine, for that matter - should be able to run 3000 RPM all day with no negative effects. Fuel mileage isn't going to be great no matter what RPM you're running, as pushing a brick through the air at 80 MPH takes a lot of energy. If you're considering an overdrive to improve fuel mileage, take a minute to figure out how long it's going to take you to recoup your investment.
Old 06-29-2021, 12:08 AM   #12
Ptjsk
Gear Vendors in my '72 Jimmy was definitely one of the best modifications I did to the rig!
350 transmission, 33" tires and 410 gears. Cruises real nice at 75-80mph. Went across Nevada last year and many times was cruising 85-90.
But.....don't even think that you're going to get decent fuel mileage. I don't really know how, but a few times I was just a hair over 12 mpg. Most of the time though I'm between 10-11 mpg.
Pat
Ptjsk is offline   Reply With Quote
Old 06-28-2021, 10:09 PM   #13
gmc684x4
-50 my truck in the back yard was the only truck in the yard to start
68 gmc 4x4 350 4x4 .
Good cold crank battery good tune up good antifreeze I always mix 60 40 synthetic oil good to go
gmc684x4 is offline   Reply With Quote
