06-28-2021, 02:40 PM | #1 |
1962 235 hydraulic clutch flex hose
Hi I recently replaced the brake lines on my '62 and the kit came with two stainless sections of clutch line but no flex hose between them. Anyone find one or a solution? Thanks, Chris
06-28-2021, 03:50 PM | #2 |
Re: 1962 235 hydraulic clutch flex hose
I used a piece of stainless braided hose with fittings on either end to connect to the hard lines. I only needed about 8". If you have a hydraulic hose shop around, they should be able to make one up for you.
06-28-2021, 04:51 PM | #3 |
I think your solution is the only way to go. I can't find anyone that makes a clutch line like the original (I have a 61 C-10). Any pictures would be helpful. Thanks - GPK1961
06-28-2021, 10:50 PM | #4 |
My old one and one I had made at a local shop "Royal Brass"
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
06-29-2021, 10:24 AM | #5 |
Thanks Sal. Very helpful. GPK1961 Frisco TX
06-29-2021, 01:17 PM | #6 |
I had one made at a local hydraulic hose shop for $45.00. Here a picture of the old one with some measurement.
06-29-2021, 01:31 PM | #7 |
Thanks, again very helpful. GPK1961
07-01-2021, 12:54 PM | #8 |
Thanks for the solutions guys. I think the hydraulic hose from a shop sounds like it would be the most original looking. CB
07-04-2021, 10:26 PM | #9 |
I bought mine at inline tube
