![]() Join Date: Feb 2020
66 C10 Longbed Parting Out
1966 C10 Parts Truck
LONG BED NO TITLE Buy the entire project for $900 -- OR -- Buy individual parts as follows Steering Wheel ..............................*** S O L D *** Column shift column............................. $200 Dashboard - Unmolested ...................... $100 Speedometer Cluster with gauges .......... $150 Full Bed with Tailgate............................. $350 Cab - Missing most of roof and pillars but has good firewall and floor sheet metal.................................. $100 Hood .................................................. $150 Cowl extensions outer shoulders (each).....$ 50 Cowl Vent...............................................$40 Fuel Tank OEM fresh paint........................$ 50 Fuel Tank OEM unpainted.........................$ 25 Bucket seats ( no mounting brackets).......$100 Heater box (under hood core condition ?)....$50 Heater box (under dash)...........................$50 Clutch & Brake pedal assembly.................$125 Gas Pedal Assembly..................................$50 Chassis not for sale separately No Doors No fenders No inner fenders No engine No Transmission No hood Hinges Last edited by dream66; 07-10-2021 at 10:31 PM. |
Re: 66 C10 Longbed Parting Out
More pics
Would you be willing to cut out the tranny hump and ship? Thanks
No problem. I got a pic this afternoon. Not a great pic but the hump was well preserved by the sound deadner.
Can you provide some measurements so I will know where to cut? EDIT: You know that you can buy that part new from LMC for $145 . After cutting mine out it will only be about $30 less and shipping is gonna be about $25 - $30 Last edited by dream66; 07-13-2021 at 03:34 PM. |
It's the short low hump for 3 speed manual. Let me get a pic of it and identify the cut lines before you decide.
![]() ![]() ![]() Join Date: Jan 2018
Any rust through on the rear corners of the inner roof panel? That almost triangle looking spot where the inner roof meets the inner back wall and upper door frame.
If you're willing to cut a section out and ship to 30188, I can get a picture of what I need
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
That area is rust free except for the outer surface rust. Post up that pic of the section you need cut out.
It may take me a couple days to get to it due to the rain and mud where it's parked. |
The main need is the passenger corner, but I could also use some extra from the passenger side to help repair a couple spots on the driver's side. The driver's side corner looks ok to me.
I'm thinking it only needs to go about 6 to 8 inches above the door frame line. I think I might also need a little bit from the passenger corner on the inner back window panel (right under the coat hook) Thanks!
Got it. I'll take some pics of my inner cab with lines drawn along the proposed cut lines for your approval.
Sounds good, thank you!
Any interest in selling a tail light bezel ?
dont want to hear excuses, i want to hear solution(s) |
I would but they are spoken for along with both complete housings / lenses.
Is there a factory dash speaker?
If so,i need the little hook and wing nut that holds it in place.thx |
#15 |
Will this work?
#16 |
I already robbed that part for my brother's C10. Sorry
#17 |
That line looks good to me. You can cut the front section right before it starts to curve downwards close to the windshield. My truck is a 63, so that front corner is different
What's your price shipped to 30188?
#18 |
$30 per side + $25 shipping = $85 total
#19 |
I'll take just the passenger side as that's the one that really needs help on the corner, and then I can use the rest to fix the spot that's more towards the front on the driver's side.
Do you prefer a money order or PayPal?
#20 |
paypal to seebrolee@gmail.com
#21 |
I sent a pic of the problem area I’m not sure how much I would need
#22 |
I appreciate that and I will give it a try
#23 |
Do you know if it’s a 1year deal only in the 65?
#24 |
No sir, Don't know.
#25 |
I will send paypal later tonight for the roof section. Thanks!
