Hole in floor pan suppose to be there?
I bought a 72 C10 short bed truck and it has a hole in the passenger side floor board that looks like its suppose to be there, but past C10 trucks I have had didn't have this hole. Any idea if its something a previous owner did to the truck or something from factory?
67 C10 SWB Chevy |
Re: Hole in floor pan suppose to be there?
That almost looks like a drain hole for something maybe a AC system?
Doesn't have factory A/C, unless at some point it had some kind of aftermarket....but no A/C components on truck.
67 C10 SWB Chevy |
![]() Join Date: Dec 1999
That was added by someone. Looks like an electrical fitting called a chase nipple. They are used to protect wires going through the side of a metal box. Probably has a ring nut on the bottom side.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Ahh, does look like an electrical box part for home wiring. Not sure what the thing is next to it at 11 o'clock.
It is not a factory a/c drain at all. |
#6 | |
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Was cab on a work truck at some point.We use to put a hole like that in for a rod to turn on a PTO.
No, cab Vin, frame Vin and glovebox sticker all match.
67 C10 SWB Chevy |
#10 | |
IIRC, my 72 had the "rubber floor mat retainers" and the aftermarket Front Under Carpet Soundproofing that I got from GMC Pauls had holes in the right places to match those studs. Either way, by the time the tar-like soundproofing and carpet was installed...they don't show and held the soundproofing in place nicely. Dual function, maybe...OR there are different studs for the soundproofing vs rubber mat? IDK. I'd leave them until you get to installing the tar mat and carpet.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#12 | |
All about them K’s
![]() Join Date: Jun 2014
My 72 K20 is a cheyenne and has those floor studs too. I laid the new carpet right over them. I just assumed maybe the oe jute padding hooked to them.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Backside of hole
67 C10 SWB Chevy |
#15 |
That's an electrical conduit fitting.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#16 |
Jeez . That was used to dispose of weed when you were being pulled over . Less obvious than chucking it out the window
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#17 | |
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
#18 |
When you really have to pee on those long trips and don’t want to stop…
