Old 12-23-2003, 11:29 PM   #1
blink32
blink32's Avatar
Help with Gas Filler Neck
Been reading the site for a while and now I've got a worthy question.
I've started to replace the aged and cracked rubber gas filler necks. I got new necks, struggled with getting the stock neck off the passenger side tank and now I'm stuck (this is on a 76 dual tanked K10 by the way)
My problem, I can't get the new neck on. Its a 1 3/8" rubber hose with a 90 deg elbow, and I checked the stock one I removed and it was also a 1 3/8". But the Metal gas filler lead that it connects to is about 1 1/2" or so. But there's an additional hump or lip that makes it like 1 5/8" or something. I've tried everything I can think of, heat the hose with a heat gun and try to jam it over, lube the neck and hose with grease, freeze the neck and boil the hose. But its just not working. The best I've managed to accomplish is to get the tube wrapped over the initial start of the metal pipe before the lip. But I can never get it past that. Is there some other trick or tool that I can use to stretch this hose or am I just not trying hard enough with the current methods? I really need to fix these. Thanks for any help.
blink32 is offline   Reply With Quote
Old 12-24-2003, 01:16 AM   #2
bigblock73
yeller
bigblock73's Avatar
Did you try white lithium grease? I had a similar problem when I installed a Borla exhaust kit on a vehicle...couldn't get the dam rubber mounts to slide over the steel hangers on the exhaust. Sprayed the metal and they slid right in.
BTW - welcome to the board.
bigblock73 is offline   Reply With Quote
Old 12-24-2003, 01:31 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
boiling has always worked for me maybe try to stretch em a little with a tailpipe expander?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-24-2003, 08:58 AM   #4
blink32
blink32's Avatar
I did try lithium grease. Its just wayyy too tight. Slightly over-engineered in my opinion but hey, GM made sure it would never come off. And thanks for the welcome.
I'll definitely try the tail pipe expander, maybe boil it, stretch it and let it cool and see if it will hold some of the stretch then re-boil it and see if I can get it on there. What a pain this is turning out to be but thanks for your help.
Old 12-25-2003, 07:56 AM   #5
Nvbowtie
Nvbowtie's Avatar
The one I got from chevy duty had different sizes at each end.
I think you may have the wrong hose.
I think there were 2 or 3 different styles for 73-78 era
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 12-25-2003, 10:41 AM   #6
blink32
blink32's Avatar
What is Chevy Duty? If I can find that out I'll contact them and see if they have a different hose for me.
Old 12-26-2003, 01:21 AM   #7
Nvbowtie
Nvbowtie's Avatar
http://www.chevyduty.com
Old 12-29-2003, 09:16 AM   #8
blink32
blink32's Avatar
Thanks, I'll check with them
