Firewall holes for Vintage Air
Ok, I've searched both this site and the Vintage Air site with no luck. What I am looking for is a paper pattern or dimensions for drilling a shaved firewall.
I have a Vintage Air Sure Fit system but since I shaved the firewall they did not send the metal piece to cover the factory heater hole. There is no pattern or dimensional layout information in the manual. If anyone can supply me the information or site I would greatly appreciate it. Thanks, ![]()
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
![]() Join Date: Dec 1999
Re: Firewall holes for Vintage Air
Here's a CAD drawing I made when I drilled the holes in my shaved firewall. I had the metal piece from Vintage Air, so I just held it up to align this template I printed. That is why none of the other holes on the plate for reference are shown. Hope it helps.
Thanks Jason you got me one step closer. At least now I have the hole layout. Just need to get a point of reference on the firewall to lay them out on.
I was counting on getting the metal filler plate to use as a reference for cutting the holes.
![]() Join Date: Dec 2013
I have what your looking for , I wanted to get as much done on the VA install before ordering the kit and another member sent it to me , I haven't done it yet but if you'll ship it back to me I'll send it to you to use ? I'll get a few pics of what I have and if it's what you need I'll send it to you ? it's the install instructions and plate . I shaved and smoothed mine as well .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
I would appreciate it Grumpy, thanks. I will pm my address to you so you can send it to me. Please have your return address on the inside of the package so that I can make sure I can read it.
Thanks for the help ![]()
Here is what I have, Like I said another member was nice enough to send it to me when he was done with it and I haven't used it yet so I need it back when your done . And when I'm done I'll send it to the next guy that needs it .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 08-01-2021 at 04:30 PM. |
![]() Join Date: Jan 2021
As far as I know, some people have been running the restomodair bulkhead.For running the heater hoses and a/c lines between the inner fender and fender to the far right side of the firewall. Give it a look. Thanks Chuck
Posted via Mobile Device |
Well thanks to Jason and Grumpy I now have a paper pattern for the hole layout. It might not be exact but it should get me very, very close to where the holes need to be. Attached is a picture of my paper pattern that I will be using to drill my holes. I will give an update once I drill the holes.
A quick update on the holes specifically the 3/8" hole. Called Vintage Air and they stated that the hole was for the heater control valve. My plan is the reroute the wire so that I don't have to drill the hole and keep my firewall as smooth as possible.
