Old 07-30-2021, 12:17 PM   #1
1774btcrew
1774btcrew's Avatar
Did the late Squarebodies come with aluminum top SM465 transmissions?
I had always thought all Squarebody SM465 transmissions had the cast iron tops but a some point I pulled a shifter out of a squarebody that must have been an aluminum top as the portion that goes into the transmission is larger diameter than the earlier ones. The shift levers on the OBS trucks that I know came with aluminum tops only had one bend as the dash is shaped completely different. Has anyone else noticed this?
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 07-30-2021, 02:57 PM   #2
kipps
Re: Did the late Squarebodies come with aluminum top SM465 transmissions?
Interested in this as well. As far as I know, the iron-tops had the forward shifter position, and were only used in the squarebody's. The aluminum-tops had the rearward shifter position, which was the same as the nv4500 that replaced it, and came in the gmt400's. I've never heard of a forward-shift-position with an aluminum top.
I've personally never seen an aluminum-top, so I can't comment on the specific differences in the shifter.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 07-30-2021, 03:48 PM   #3
1774btcrew
1774btcrew's Avatar
The bends on the shifter are identical to the earlier ones. I was really surprised when I saw the larger diameter on the part that goes into the transmission
Old 07-30-2021, 05:17 PM   #4
kwmech
In the square it would have been in the 88-91 1 ton only---OR if ordered special it could have showed up in either the Suburban or Blazer. 1/2 and 3/4 ton were the newer body style. In 1992 they got away from the 4 speed and went to the 5 speed (NV4500)
Old 07-30-2021, 07:24 PM   #5
kipps
But did the square body style ever get the aluminum top? Or was the aluminum top only used for the gmt400 trucks, like we've always assumed?
Old 07-30-2021, 10:11 PM   #6
v30crewcab
v30crewcab's Avatar
no the aluminum top was to move the shifter back for the new bodystyle. never came in a square.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 08-01-2021, 12:40 PM   #7
Nick_R_23
Nick_R_23's Avatar
Crew Cab Squarebody (as well as K5 Blazer/Suburban) ended in 1991.
Old 08-03-2021, 01:33 PM   #8
1774btcrew
1774btcrew's Avatar
Yep. I actually sell squarebody parts for a living and want to be able to sell this shifter. It is larger diameter at the base.
Old 08-03-2021, 01:34 PM   #9
1774btcrew
1774btcrew's Avatar
Basically all of the shifters I have had before are 24.4mm at the base. The later model is 29.2 mm at the base and this is the only one that I have seen like this.
