Old 08-01-2021, 06:48 PM   #1
65truckowner
65truckowner's Avatar
remove cab or not
I am doing a patina restoration on my 65 c10. I am redoing all the interior and detailing under the hood. I wanted to leave the cab on the frame but I need to install both floor pans and rockers inner and outer. It also needs the cab braces so should I do this on the frame or just pull the cab. I already have the front clip off and am going to strip the interior.
65truckowner is offline   Reply With Quote
Old 08-01-2021, 07:42 PM   #2
mongocanfly
mongocanfly's Avatar
Re: remove cab or not
Gonna be alot easier if your not having to work around the frame and other parts...if your that close ,it wont be much harder to just pull it
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-01-2021, 10:11 PM   #3
SkinnyG
SkinnyG's Avatar
I would for sure pull the cab. If you can lay the cab on its back, it makes it easier to do the work, and you're going to want to seal everything up so it doesn't rust.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 08-01-2021, 10:31 PM   #4
Getter-Done
Getter-Done's Avatar
It will make it easier for you.
You will get a lot better access to places you need to work on.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 08-02-2021, 01:22 AM   #5
62bagger
62bagger's Avatar
I wish I had the room when I started my build to remove the cab. I cleaned and painted as well as I could but it would have been a better result removing the cab. Now I have a shop with room to work I am too far along for that.
62bagger is offline   Reply With Quote
Old 08-02-2021, 06:47 AM   #6
65truckowner
Thanks for the replies. The cab will come off. I may start working on it today after work.
Old 08-05-2021, 09:07 PM   #7
PGSigns
PGSigns's Avatar
Before you start make sure your doors fit good. Then weld the bracing in the cab to keep it from moving. X braces in the doors and braces from side to side. I have seen several cabs that had moved when the cab mount braces rotted and several more that moved when the work started and the cab was not braced.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-06-2021, 10:35 AM   #8
88Stanger
88Stanger's Avatar
Jimmy
I was just going to say this basically same thing, jus make sure you brace up the inside just to be safe. I am happy you are taking the time to do it right. I can understand not wanting to because you may find more issues and it will take more time, but in the end you will be so happy you did. I have done 2 ("66 now and previous "69) of these now and this latest one is far beyond what i did for my "69 and i could not be happy that i took the time to do it this way, BUT damn it is not fast at all!!! LOL This will be year 2 in the making but when i am done next year, it i will be so much more happy that i took the time to do it right, right in my mind... lol
Good luck and keep us updated... PS PICS PICS PICS ....
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 08-06-2021, 10:05 PM   #9
65truckowner
I have started a build thread and have some pictures there. I will post more there soon
Old 08-07-2021, 07:13 AM   #10
66C10LB
There will always be more patching do do than you think. It may be a good idea to replace body mount bushings while you are at it. Removing the cab will make it easier.
66C10LB is offline   Reply With Quote
Old 08-07-2021, 07:42 AM   #11
65truckowner
Yes I am planning on replacing the bushings.
Old 08-08-2021, 08:10 PM   #12
65truckowner
IMG_4185 by Daniel Crymes, on Flickr
Old 08-09-2021, 08:37 AM   #13
The Rocknrod
Moderator
The Rocknrod's Avatar
It's good you did it. Find out what the issues are and get with the rat killin.
Old 08-09-2021, 08:41 AM   #14
65truckowner
Funny thing about a rat. A few years ago I had a cab in the shop I got from a old junk yard and was doing rust repair on it. I starting noticing things being chewed and found out a rat was living in the cab. I left the cat in the shop all night but rat was still in the cab. A few days later found it dead in the kick panel vent.
