![]() Join Date: Sep 2016
Has anyone installed a type 2 power steering pump
I知 thinking of installing vintage air on my big block currently I have a long water pump and a 3 core factory radiator. I have about 3/4 of inch clearance between clutch fan and radiator this is why I知 swapping to a short water pump . I知 looking at the complete accessory serpentine kits and they are set up to use the newer type 2 power steering pump and was wondering how they compare to the older style.
Re: Has anyone installed a type 2 power steering pump
Hayden makes a shorter version of their heavy duty fan clutch #2747. The shorter version is #2947. I had the same issue on a first gen Camaro, with the 2747. Changed to a 2947 and problem is solved.
Would be a much cheaper solution, unless you just want to go to a short water pump and a serpentine setup. |
#3 | |
Posted via Mobile Device |
