08-16-2021, 08:40 PM | #1 |
WTB, I need a RH rear “big window” OEM stainless trim molding, badly
No really I had my stainless professionally polished, the RH rear piece doesn’t make the cut, and I’d take a LH side too or all three if nice.
Mint condition please, RH rear anyway. Surface scratches can be ironed out, I hoping for no bends or dings or so close. Shipping is a pain, please consider that into my cost for sure, I have an "open wallet" on this, I need to put this to bed, can't do that w/o a rear window. Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-18-2021 at 01:33 PM. |
08-17-2021, 06:53 PM | #2 |
Re: WTB, I need a RH rear “big window” OEM stainless frame, badly
Ttt
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-18-2021, 10:01 AM | #3 |
SpecialK has a bunch of trim stashed away .What's wrong with the pieces you have ? I might be a buyer ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 08-18-2021 at 10:07 AM. |
08-18-2021, 01:55 PM | #4 | |
It wasn't serviced and needs some attention for an outer bend, which looks negligible to me. It has a minor dimple as well, otherwise good.........But I'm still looking for a replacement if one is out there, thanks for the lead. The set I had polished was something I bought years ago. After polish they tell no lies, the RH side has four small dimples on the very top edge because why? Seems the wrong tool was used to remove it. It also has a small dimple near the lower edge of the top. I messed with that a little with some improvement, though perhaps it's my imagination. Only thing I've been able to come up with is a massage using a tapped up B/A flathead & heat.............. When it's said and done this piece should become available. I can take more pictures, but at the moment I'd like to resolve what I'm using first. The shop said they couldn't repair the dimples because it's double walled............Hmm! The LH side of what was polished has one minor dimple, same with the lower, but they're nice.
08-18-2021, 04:08 PM | #5 |
I have these.
67 C10 Fleetside SOLD 67 C10 SWB Fleetside 67 C20 Fleetside 68 C10 Fleetside 68 C20 Fleetside SOLD 72 k20 Pay Pal: Grant.Furneaux@gmail.com |
08-18-2021, 07:13 PM | #6 |
^ That's ^ windshield and door panel trim ^ .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-19-2021, 01:43 AM | #7 |
I'll take it....... Kidding.
