08-28-2021, 12:00 AM | #1 |
Anyone running Torq Thrust 17x7 front and 17x8 rear?
I’ve decided on buying a set of VN309 TT O for my ‘66 short fleet. I’ll be doing a 3/4 drop and it already has discs up front.
I can’t decide on 17x8 all around or use 17x7’s in the front? The 17x7’s only have a 4” BS and the 17x8’s have 4.5” BS. A couple of my truck junkie friends are telling me to use the 7’s up front but I’m not convinced. Is anyone running this setup? I sure cannot find any pics. online or any other posts concerning my question. Please post pics. if you have this setup! Thanks! |
08-28-2021, 08:08 AM | #2 |
Moderator
Re: Anyone running Torq Thrust 17x7 front and 17x8 rear?
I have VN615's with 16X7's up front with a 4" backspace and 17X8 in the rear.
08-28-2021, 09:05 AM | #3 |
08-29-2021, 08:40 AM | #4 |
Moderator
08-28-2021, 09:45 AM | #5 |
09-06-2021, 01:51 PM | #6 | |
09-11-2021, 02:40 PM | #7 |
Will you need two spares if you offset sizes?
09-11-2021, 04:42 PM | #8 |
Moderator
09-12-2021, 12:16 AM | #9 |
Or.... Treat the situation like a newer cars (late 70's - a few years ago) set-up that utilizes a 'TEMP' spare to get you to your next destination. One wheel/tire used as a temp gets it done until the situation can be corrected. Something close enough/between the different sizes will get the job done.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-12-2021 at 12:23 AM. |
09-19-2021, 09:08 PM | #10 |
09-11-2021, 03:47 PM | #11 |
Not if the OD of the tires are the same
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
