09-04-2021, 09:45 PM | #1 |
front suspension
This front suspension is 1985 8 lug. My trucks 1966 C20.
they want 350.00. Just want your opinion of it to replace my drum suspension |
09-04-2021, 11:01 PM | #2 |
Re: front suspension
The price seems fair but will your wheels clear the calipers?
09-05-2021, 01:56 AM | #3 |
Sounds like a fairly economical way to upgrade to disc brakes. I would likely replace all of the ball joints, inner and out tie-rods, pitman and pull man arm. They will add to the cost of upgrading but I'm of the mind to replace it all now while putting it all back together.
09-09-2021, 09:58 AM | #4 |
I’m in the process of the same swap (88 3/4 suburban front end onto a 1966 C20) - you’ll need to accommodate the power steering and change in brakes as well, but the price seems right.
09-09-2021, 11:47 AM | #5 |
I paid 300 for a 73 1/2 ton suspension. Since this is a 3/4 ton you might be able to find one at Pick and Pull for a fraction of that price.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
09-10-2021, 09:39 AM | #6 |
If it's already pulled & everything is there, the price is not bad. Free is always better but if obtaining the parts is easier & everything is there, time is money. I would try to get the factory 8-lug front wheels as part of the deal if @ all possible.
09-10-2021, 03:03 PM | #7 |
Decided to skip on it and get spindles that match my truck so I could use original parts. Thought down the road it would be easier to keep track of.
09-10-2021, 04:32 PM | #8 |
I picked up a c20 full rolling chassis 1977 (?) for a future conversion on a 1964-1966 C20-30
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
