Old 12-26-2003, 04:56 AM   #1
TIMSPEED
TIMSPEED's Avatar
Is this everything I need to bag my 75?
Aside from a stepnotch (which I'll have made)
Is this a complete parts list?
1.) ARF11800 "Cool Ride" Kit for 73-87 C10 = $524
2.) ARS14500 Parallel 4-Link with Weld-On Bag Mounts = $799
3.) ARC4700 "BIG RED" Compressor System = $1495
So, for all the parts it would be something like $2818 + Tax and Shipping and such...right? Seems like it would also be a pretty straight forward install job too...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 12-26-2003, 11:19 AM   #2
Izzy
Trucker.
Izzy's Avatar
That's it and I'd suggest you mount those outside the frame because we tried mounting mine inbetween the rails and the mounts are too wide and get into the differential and you're not supposed to weld to it since it's cast.
Izzy is offline   Reply With Quote
Old 12-26-2003, 12:17 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
There ya go! That's everything you need. I would suggest a couple of things to consider though.
I'm not sure what air tank that is, but it looks like either a 3 or 7 gallon because of the shape. I suggest two 5 gallon tanks instead. The 5 gallon tanks are longer, but not as big around. They hide better if you install them under the truck. Since you are using a 4 link, you should be able to mount them outside the frame rails behind the axle.
I would also delete the shocks from the kit. If there is a place that they compromise quality in the kit, it's the shocks. Get a credit, and buy your own....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-26-2003, 10:07 PM   #4
BaggedC10
Under construction!
BaggedC10's Avatar
N2TRUX---That is a 5-gallon air tank.
TIMSPEED---This setup looks familiar! Including the PST front-end kit and DJM spindles we both have. I would spend the extra $300 for the ARC4800 BIGRed Max compressor system (This is what I have). You will want the second compressor, air tank, and 1/2" line/fittings. Shoot, the Viar 400 cost $279 alone through ART!
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 12-27-2003, 01:11 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Hmmm? BaggedC10 They must have changed the dimensions of the 5 gallon tank. Mine are from an old kit I bought off a guy that he never used. It was when the Ride Pro was the biggest system ART had.
TIMSPEED he is right about the upgrade. That wasn't an option when I bought the kit for my 77. The extra compressor and air tank make that a pretty decent deal alone....
Old 12-29-2003, 11:39 AM   #6
bagged81
Signals in the bumper.
bagged81's Avatar
How long are the bars on that 4-link kit?
Will you have to relocate your fuel tank?
N2TRUX, what shocks are you using?
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 12-29-2003, 12:52 PM   #7
Izzy
Trucker.
Izzy's Avatar
It's the same 4 link you have it's just got a different part #. Yes you can keep the tanks.
Old 12-29-2003, 01:23 PM   #8
bagged81
bagged81's Avatar
When I bought mine, I was told that there was 30" bar option and 20" bar option. With the 20" bar you would not have to relocate the fuel tank. I was just wondering if they told him that too.
Not sure if this is true or not, but I had to relocate my tank. I asked for the 30" bars, but I never did measure them to check.
Jeff C.
Old 12-29-2003, 01:43 PM   #9
Izzy
Trucker.
Izzy's Avatar
Well I didn't relocate the tanks on the 83 so I'm guessing I got the 20 but I never measured the bars either as ART set the length before sending them to me and the pinion was dead on.
Old 01-07-2004, 11:16 PM   #10
Slammed '87
Slammed '87's Avatar
what would be the advantage of the longer ones? Ride quality? You wouldn't gain more or less lift as the bags are not mounted to the 4 link like a 2 link right? Just curious as i am ordering mine soon.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough!
Slammed '87 is offline   Reply With Quote
Old 01-07-2004, 11:58 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
I guess I over looked this question. I have my Blazer, and my 77 pictured so I'm not sure which one you are asking me about
