Old 09-21-2021, 09:53 PM   #1
Bullzak_83
Alt Mount
Question, does anyone have a picture of how this bracket for the alt,mounts.
I know this is not right, but I'm trying to figure out the correct way of setting it up. It's on my 70 cst 10. I have cut a extension to bring it out away from the block. I have evan noticed that the fan on the alternator was dragging the bracket somewhat, I actually ground the bracket, so it would clear the fan.
Bullzak_83 is offline   Reply With Quote
Old 09-21-2021, 10:12 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Alt Mount
Here is a 307, same water pump as 350, short water pump same brackets
http://67-72chevytrucks.com/vboard/s...89&postcount=8
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-21-2021, 10:24 PM   #3
zosoppp
Re: Alt Mount
on my 1970 c10, sbc350, I have the upper arm connected to the REAR of the alternator's top ear with the bolt going in from the firewall side. Also the engine end of the upper arm is connected to the head with the same bolt as the base, no spacer forward.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is offline   Reply With Quote
Old 09-21-2021, 10:31 PM   #4
Bullzak_83
Re: Alt Mount
I've to attach on the back side, but the width of the bracket would not allow the bolt hole to line up with the bracket, i guess I could modify the bracket
Old 09-21-2021, 10:33 PM   #5
Bullzak_83
Re: Alt Mount
Could you resend the link, i couldn't get to open.
Old 09-21-2021, 10:31 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Re: Alt Mount
You have the wrong adjustment arm. If you notice the one on zosoppp's engine has a lot more curve to it. That is the one you need so it can be mounted on the back of the boss that the bolt goes into.... I think it also has an offset where it bolts to the lower bracket.
LockDoc
Leon
Old 09-21-2021, 10:39 PM   #7
zosoppp
Re: Alt Mount
LockDoc
Here is the lower end of the upper bracket.
Old 09-21-2021, 10:41 PM   #8
LockDoc
LockDoc's Avatar
Re: Alt Mount
OK, I see that that one is straight. Thanks.
LockDoc
Leon
Old 09-21-2021, 10:43 PM   #9
zosoppp
Re: Alt Mount
LockDoc
Actually I was thinking that there might be a little bend in it from that photo, hard to tell, though.
Old 09-21-2021, 10:47 PM   #10
LockDoc
LockDoc's Avatar
Re: Alt Mount
Could be. A picture of the whole arm from more straight on would be the only way to tell for sure.
LockDoc
Leon
Old 09-21-2021, 10:36 PM   #11
Warrens69GMC
Re: Alt Mount
here
https://67-72chevytrucks.com/vboard/...89&postcount=8
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
