09-30-2021, 07:19 AM | #1 |
Brake spacer
My master cylinder and booster kit came with a metal spacer to put in the master cylinder for the push rod if needed. Are most people using this ?
09-30-2021, 07:32 AM | #2 |
Re: Brake spacer
Here is the master. 1" bore
09-30-2021, 09:15 AM | #3 |
Re: Brake spacer
It's really not an option about whether you want to use it or not, you either need it, or you don't. Measure the rod extension out of booster and compare with recess of MC piston.There should be slight clearance.
Some MCs have a recessed piston, others are more flush. |
09-30-2021, 09:41 AM | #4 | |
Re: Brake spacer
09-30-2021, 11:03 AM | #5 |
Re: Brake spacer
something like .020. The bigger the gap, the more pedal movement before actually applying brakes.
Before mounting your stuff, on the bench you should be able to see whether to use the spacer/extender or not. It looks to be 2" or so? It will either go in there naturally or you will have to force the piston down to mount the MC to booster. The MC should just mount to booster without any spring pressure. post of pic of the booster rod. Last edited by geunther; 09-30-2021 at 11:28 AM. |
09-30-2021, 11:52 AM | #6 | |
Re: Brake spacer
10-05-2021, 02:48 PM | #7 |
Re: Brake spacer
I actually had to add a washer to each of the studs on the booster to get the master cylinder moved out slightly. Without those, it was very lightly applying pressure to my front discs. The resulting heat would build up enough to where it would create a hot spot on one or both discs, resulting in a slight grab that would devolve into a massive oscillation of the steering components. Very similar to Jeep Death Wobble. Took me some time to figure out what was causing that.
10-05-2021, 02:56 PM | #8 | |
Re: Brake spacer
10-07-2021, 07:07 AM | #9 | |
Re: Brake spacer
