Old 10-02-2021, 03:54 PM   #1
chris mc bride
chris mc bride's Avatar
Lowering springs 69 c10
Ok want to lwer my 69 panel some. I know spindles would be best.Other project dragster keeps eating money, so going cheap route.
Whats best drop to give decent drivability with springs only for while . I would like to get a set that can beused later with spindles when money allows. Thinking I read that 2" was about most I could do w/o killing ride. That would give little better look although not exactly what I want in ned.
Suggestions? Who has better quality piece that are not over top on price.
Only the stupid know too much to learn something new.
chris mc bride is offline   Reply With Quote
Old 10-03-2021, 01:11 AM   #2
Accelo
Accelo's Avatar
Re: Lowering springs 69 c10
The typical limiting factor when lowering a truck with springs only is the length of the alignment studs on the upper A arm. You know the ones with the shims. As you go lower the A arm has to move out and you quickly run out of stud length as you add shims. I don't know where this limit is on a typical truck. The ride issues and the rubber stops are another issue. Others that have gone this route will likely chime in.
Accelo is offline   Reply With Quote
