Location: 3,018 feet above the SoCal/Mojave Desert region.
A/T pedal assembly differences from M/T.
So my truck was once a column shifter but the previous owner (my uncle) changed it to a
T-400 A/T. If I was to just remove the clutch pedal and whatever it moves upon, will the brake pedal be fine or does the brake pedal need the clutch attachment?? Hope that made sence?? Thanks |
Who Changed This?
![]() Join Date: Jan 2013
Re: A/T pedal assembly differences from M/T.
You should be good to go by just putting in spacers for any gaps that removing the clutch pedal stuff leaves. If you're not in a hurry, maybe look at the wtb/wts ads and see if you can make a swap with someone going the other way.
All about them K’s
![]() Join Date: Jun 2014
No need to buy another pedal setup. They are the same brake pedal assembly, mt vs at. The clutch pedal is the only difference. Pull the clutch pedal out and run it. No spacers or anything else needed.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 10-09-2021 at 09:40 PM. |
Senior Moment
![]() Join Date: Mar 2002
Exactly, the clutch pedal runs though the brake pedal, slide clutch out and your done
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
