10-11-2021, 07:14 PM | #1 |
relay type and quality
Looking for some opinions on. is there a big quality difference in different brands of relays that are used on cooling fans and fuel pump. I just blew one on the ecm that was installed when I sent my harness out to get it re worked.(2 relays 4 fuses) Everyone I have sent out comes back with the standard type relay set up. Are people replacing these with better quality relays?
Your thoughts. |
10-11-2021, 08:03 PM | #2 |
Re: relay type and quality
One of my pet peeves is cheap relays. I use these.
https://www.racetronix.biz/p/relay-c...s-iso/rycs-001
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
10-11-2021, 08:26 PM | #3 |
would you change the socket also or just the relay?
10-11-2021, 09:30 PM | #4 |
I use the metri pack socket that comes with the relay.
10-12-2021, 04:45 PM | #5 |
The aftermarket harnesses I've bought used Hella. Never had a failure. I've used Painless fan kits with good success. What ever you use make sure they are rated for the max amp draw.
10-22-2021, 04:53 PM | #6 |
quick question. All my relays are 4 prong. Can I use 5 prong relays on four prong applications? Thanks
10-22-2021, 08:50 PM | #7 |
BMW & ASE Master Certified
doesn't sound like factory fuse layout... probably overloading the circuits? never understood why people who rework harness do that type of quality...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
