Old 10-13-2021, 01:06 PM   #1
ellisjay2
Oem metal fan???
I'm looking for the oem metal fan, with clutch, and shroud,so far all I've found was one on Amazon around 40 bucks, Hayden clutch around 30, I'm not going electrical fans on this route, everything is delayed order and higher prices like lmc, classic industries, if Whitney, Amazon is fastest delivery....
I've found a few later years on ebay...would a 90s 5.7 fan fit an 80s 5.7, looking at it I almost wanna hope they're interchangeable....also found a few 88 and 89 years...my sierra is 85.
: Eli540
86 gmc 2500 longbed Carb 5.7, rwd,
400 tranny.
ellisjay2 is offline   Reply With Quote
Old 10-13-2021, 05:45 PM   #2
roboticjunky
Re: Oem metal fan???
You need a mechanical fan for 87 and older because your water pump spins clockwise since it has v-belts. (85-87 had v-belts for accessories and serpentine style belt for the alternator.)
88 and newer had serpentine belts and the water pump and fan spun counter-clockwise.
So look at these two fans.
https://www.summitracing.com/parts/der-17119
https://www.summitracing.com/parts/rnb-621-323
I think the stock fan that was on my 87 was 19".
roboticjunky is offline   Reply With Quote
Old 10-13-2021, 07:16 PM   #3
ellisjay2
Thanx, I'm going with 17119 hopefully clutch I found will fit as Well, but read reviews on summit and same model owners got good results...
: Eli540
400 tranny.
Old 10-13-2021, 06:57 PM   #4
Dead Parrot
Pretty sure there are different shrouds depending on year, engine size, AC/no AC, Auto vs Manual trans.
Plus variations on radiator hold down brackets and covers.
The different options got different radiators and therefore different shrouds, etc.
Dead Parrot is offline   Reply With Quote
Old 10-13-2021, 07:14 PM   #5
ellisjay2
The 17119 I found on Amazon also, but it's around same price as summit, just have to make sure it fits Hayden clutch I posted in pic , summit is 40 mins away from me, but I'll have them deliver instead. Gosh I'm so regretting losing my original fan.....
: Eli540
400 tranny.
Old 10-13-2021, 07:22 PM   #6
wazzabie
GM had a voluntary recall on the metal fin fans. I know for a 1978 350 it was first recalled decades after 1978. The fins would remove from the rivets and become a projectile. The replacement fan blades which I bought was just two pieces of metal and not the fin style of fan.
wazzabie is offline   Reply With Quote
Old 10-13-2021, 07:30 PM   #7
roboticjunky
For the fan shroud, you can look in junkyards, Facebook, Craigslist, eBay, here, or resto websites.
My 87 had the 19" fan and the truck had A/C, 350, automatic, and 4x4. So you're going to have to check and make sure the shroud works with your fan. eBay has a few different ones on there right now.
