Active Member
![]() Join Date: Jan 2008
73-76 doors
On 73-76 doors, the panels are shorter than the later style 77-80. They are also getting harder to find decent replacements for as the later style are more plentiful. It appears as the inner skin is the same, but on the lower portion of the panel flare on the later style there were holes from the factory that accommodated the taller panel. My question is does anyone know if this is the only difference and if so could you just fill the holes if you want to use the earlier style door panels?
![]() Join Date: Dec 2014
Re: 73-76 doors
Unfortunately, there is a bit more to it than that: I am in the same boat, I have a beautiful pair of 73 door panels that I assumed I could use in my 81. I guess someone skilled in fabrication can make it work, but someone skilled in fabrication can do pretty much anything. See photos below, there would be a lot of modifying and/or fabrication involved. Seems like it would be easier to find and reskin some OEM 73 doors instead.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
#3 | |
Active Member
Re: 73-76 doors
Re: 73-76 doors
I think if you are willing to tackle it and are patient, you might do exactly that. If you try I would love to see the progress because I might do the same.
My understanding is that the internals are also somewhat different since the change in 77 was to accommodate electric window and locks; ie you might find that there is no boss to screw your armrest into etc. But if you are willing to put in all that work I suppose the rest is just a little more work. It is interesting that the panel flare you are referring to was an actual cosmetic feature 73-76, and that it was simply covered up from 77-91. I had not noticed that before.
#5 | |
Active Member
Re: 73-76 doors
I’m just thinking of worst case scenario in case I can’t find replacements for 3 of my projects. |
Re: 73-76 doors
Subscribed
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
