grill support differences
Hey,
I posted last week about info on converting my 63 grill to 64-66 due to availability. I noticed in my product search that the grill supports also changed after 63. Looking for info on the difference. If I see something online I want to be able to act on it without any doubts as if it will fit. I started to bang out the damage from the deer and might be able to salvage some of the 63 grill but the support has a few twists I can't 'un-bend' HA! From what I can tell it may just be the location of the headlight support mounting holes. As always thanks in advance!
--Life looks better through a curved windshield-- |
Moderator
![]() ![]() Join Date: Aug 2011
Re: grill support differences
This might help, sure is a lot of info - http://67-72chevytrucks.com/vboard/s...d.php?t=531285
![]() ![]() ![]() Join Date: Jan 2018
The 60-62 grille support panels are different at the cutout of the frame because of the height difference of said frame. The 63-66 supports are the same except for the 64-66 supports have 3 holes each side for the grille. I used a 64-66 support for my 63. Drilled two new holes and was good to go
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
