Rust Inhibitors - Anyone used these Products
I'm looking for some type of rust inhibitor that will slow down the rust formation in hidden cavities like between the front inner and outer roof panels or the rocker panels. The KBS Cavity Coater and 3M Cavity Wax Plus both have long wands which I could put through the Visor Hole for the that roof cavity and that hole in the front of the rocker to do those. Are there better products for already rusty areas like these that you can't clean first that have these long wands or can be used with some sort of sprayer?
I did a quick search on this forum and found these products mentioned in this link being used during repairs when you can clean off the areas, but I haven't found anything about how they work with already rusty areas http://67-72chevytrucks.com/vboard/s...d.php?t=735737 These areas in my trucks don't show signs of rust on the outside, but I know there's rust in there and just want to slow it down. |
![]() Join Date: Jul 2015
Re: Rust Inhibitors - Anyone used these Products
Biggest thing that will slow it down is dry and clean. The moss, dirt, broken down leaves all hold moisture in those hidden areas.
Plain ole motor oil may suit you better, I had an area under the front wheel fender and the under the fender I had soaked in wd40. It was super clean and had kept the rust at bay for over 10 years. Old timers used motor oil on the underside of their chassis for years in the farm belt, linseed oil also. |
![]() Join Date: Feb 2016
At work I have used Fluid Film as protection from rust and corrosion on ocean going tugboats. It works good but must be reapplied from time to time. Plus it is biodegradable and non toxic.
On my Burban I went with a more toxic product POR15. I used a paint sprayer with a flexible wand to get in the nooks and crannies. See the link for more information. After 30k plus miles I am satisfied with the results. Not 100% protection but like you mentioned there is no way to clean the areas beforehand. https://67-72chevytrucks.com/vboard/...d.php?t=698377
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
I have applied the 3M cavity wax on my 72 and on a CJ. Where the wax was on my CJ kept the finish free from any corrosion. I like to use it with the long wands to get into the nooks.
![]() Join Date: Aug 2018
Doug ![]() 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US |
#6 | |
![]() Join Date: Apr 2017
Posted via Mobile Device |
![]() Join Date: Feb 2000
I used Rust Veto 342 before. Sprays on as a liquid and will run into seams and cavities but dry to a wax. Seems to be good stuff and is holding up well.
https://www.cosmolinedirect.com/cosm...st-preventive/
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Insert clever text here: |
#9 | |
I've used both Fluid Film and waste oil. Also on my Cougars I used something from Rogo products that was in spray cans. I'll have to look downstairs in the cabinet to see what the name was. It was similar to the Fluid Film but not as goopy. The waste oil worked great on my 97 Silverado but it made a mess of the driveway. It got sprayed on with a regular paint gun after being thinned a bit with kerosene. After application I'd take the truck up to a local dirt road and race around in the dust. My thought was that the dust would stick to the oil and it would stay in place longer. The truck is a daily driver that has never been garaged and it has very little rust.
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
![]() ![]() Join Date: Sep 2008
I use 3M Cavity Wax.
Thanks for all the responses, they'll really help me decide which product to use. When I first got the 69 Maroon C20, I resealed the cab's drip edge since it looked like it might have been leaking. Now I want to try to slow down any rusting cause that's one repair I really want to avoid.
Today I thought i'd use one of those Harbor Freight Inspection cameras that I had for checking out engine cylinders/pistons and take a look at that roof cavity. There's some rust, but doesn't look too bad for a 50+ year old truck. |
![]() Join Date: Oct 2020
WaxOyl is my go-to product. I have used it on my MG cars over the years. it is a wax based product that has rust converter and inhibitors integrated into it. It sprays on using an applicator that has a long flexible tube to get into areas like the roof cavity, rockers, etc.
