Old 10-24-2021, 05:22 PM   #1
Toro
Toro's Avatar
Boat paint for top?
I recall a few posts (which I can't seem to locate now) where boat paint was used on the top. Anyone familiar with this, or have tried it? If I remember, I think one post described that it was brushed/rolled on, not sprayed. Just curious if there's an advantage to this, boat paint holds up better on the fiberglass than regular paint? Anyway, I keep searching for those posts. Thanks.
Toro is offline   Reply With Quote
Old 10-24-2021, 06:56 PM   #2
hubdawg
Re: Boat paint for top?
Just finished mine today using raptor bed liner. I used the tintable base tinted to Arctic White. Works very well and I shot it at 110lbs to get a finer pebble finish. Kit is about $240 but easy to do and looks great.
hubdawg is offline   Reply With Quote
Old 10-24-2021, 10:10 PM   #3
Toro
Toro's Avatar
This was a self-leveling paint intended for boats, it could be applied with a roller and cut-in with a small brush for other places roller wouldn't reach. With the top's texture and the paint's leveling, it looked as if it were sprayed. Application sounded super easy and results were good. Maybe someone else will remember it or have used something similar.
Old 10-29-2021, 03:57 PM   #4
Ptjsk
I sandblasted (lightly), my entire top. Cleaned it, and then had the Line-x applied to it.
Very happy with the results.
Pat
Ptjsk is offline   Reply With Quote
Old 10-30-2021, 11:00 PM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I used Interlux deck paint.Mediterranean White(# INTYKA184Q). I only bought a quart.Because you thin it,it's more that enough.
It is thinned with the Interlux 333 thinner and simply brushed on.
Painted mine back in 2004, still holding up just fine.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 11-01-2021, 09:28 AM   #6
Toro
Toro's Avatar
Yes! This was the product and has to be from the post I couldn't find. I remembered it being Interlux brand now. Sad part now is that it looks like Interlux doesn't make the "Toplac" product anymore (it's not listed on their website). They have several other products that seem to have same properties.., I'm wondering if it was just re-branded? Thanks.
Old 11-01-2021, 11:20 AM   #7
BobbyK
BobbyK's Avatar
Ya, I posted that back in 2004.
I'll bet your right about the rebrand/rename on that line of paint.
Old 11-02-2021, 08:24 AM   #8
jaros44sr
jaros44sr's Avatar
Alexseal i believe is the product name, there are videos on it by boatworks
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-04-2021, 12:52 AM   #9
K5Fan
Pretty much any marine topcoat paint with UV protect will work. You can spend a lot of money and time by using Awlgrip to get a mirror finishe. Look up "Roll and Tip" paint method. Whatever you do, wear a respirator! Good Luck!
K5Fan is offline   Reply With Quote
Old 11-04-2021, 09:15 AM   #10
Toro
Toro's Avatar
I watched the Alexseal video that jaros mentioned, that looks pretty good, however it's a two part system. I'm pretty certain that the Toplac product BobbyK used was a single (no hardener/activator needed).
Watching the Alexseal video, he's only painting a small 2x2 area and it's already flashing before he can finish, not sure how that would work with an entire top?
Old 11-10-2021, 11:10 AM   #11
blazer2007
I have a 78 blazer and need to do the top . I can see the paint has wore off and can see some glass strands, do I need to put resin on these places before applying the paint ?
blazer2007 is offline   Reply With Quote
Old 11-10-2021, 11:24 AM   #12
BobbyK
BobbyK's Avatar
Yup
Old 11-10-2021, 09:22 PM   #13
blazer2007
thanks ,is my first time playing with fiberglass.
Old 11-17-2021, 04:55 PM   #14
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Thought, marine paint is heavy acrylic (Brittle), which makes it prone to cracking on flexale surfaces.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
